Ferrari F1-75
LM10
LM10
121
Re: Ferrari F1-75
AeroDynamic wrote:
22 Feb 2022, 14:48
Not even blurred shots from behind.
Re: Ferrari F1-75
From Sainz Instagram.
ema00
ema00
Re: Ferrari F1-75
I don't know if it is fast but this car is a piece of art
mariusdk
mariusdk
Re: Ferrari F1-75
Anyone else thinks that changing a damaged nose during a pit stop will be more difficult?
The access just looks very awkward.
Re: Ferrari F1-75
Radiator positioning.
Re: Ferrari F1-75
You sure it's flat and not angled inward? We can assume the louvers are the cooling exits it would make sense to maximize the surface area of the radiators relative to the louvers(that's why you slant the radiator).
Stu
Re: Ferrari F1-75
Nope! That is the entrance to the side-pod through-flow tunnel. The radiator inlet is the small square opening next to it.
Re: Ferrari F1-75
Stu wrote:
22 Feb 2022, 19:07
Nice catch! It's actually carbon fiber weave, not radiator. The outer portion of the intake must be for intercoolers.
Downforce
Downforce
Re: Ferrari F1-75
More like a tunnel for flow management. You are forbidden to have external flow conditioners, but nobody said nothing about internal flow conditioners...
Outer grills are there to shape the flow through indent on top side of the sidepods , while those inboard are used for cooling purposes.
JPower
JPower
43
Re: Ferrari F1-75
Could it be possible that they found that ducting air inside the pod and exiting out in the opening at the back of the provides some type of efficiency advantage?
Some were saying the opening for the suspension arm was just for hot air but if what you all are saying is correct, maybe its there to feed even more air to the beam wing area...
Stu
Re: Ferrari F1-75
JPower wrote:
22 Feb 2022, 20:51
Could it be possible that they found that ducting air inside the pod and exiting out in the opening at the back of the provides some type of efficiency advantage? Some were saying it was for hot air if what you all are saying is correct, maybe its there to feed even more air to the beam wing area...
https://i.imgur.com/sy2NnSS.png
That is exactly what I think that they are doing. Other than the louvres the rules forbid cooling outlets within the wheelbase, I think that the outlet for this piece is where the suspension enters the bodywork (it looks to be quite oversized for it to be just for the suspension arm).
They had reasonably small side pods last year, I see no reason why they need all of the volume that they have now for cooling. The external bodywork can then be used to control the wheel wake (and keeping it away from the beam wing) - the CFD study by @Vanja66, @jjn9128 & @Vyssion shows that to good for drag reduction. The internal flow can then be used to ‘boost’ the beam wing flow.
Downforce
Downforce
Re: Ferrari F1-75
And if it's not cooling outlet then it can be as large as they want...suspension arm is just an excuse...
jumpingfish
Re: Ferrari F1-75
Stu wrote:
22 Feb 2022, 21:00
JPower wrote:
22 Feb 2022, 20:51
Like this? Blue one is an air inside those "sausages"
Stu
Re: Ferrari F1-75
jumpingfish wrote:
22 Feb 2022, 21:29
Stu wrote:
22 Feb 2022, 21:00
JPower wrote:
22 Feb 2022, 20:51
https://i.imgur.com/8yADz05.jpg
Yep.
tpe
tpe
-4
Re: Ferrari F1-75
I am confused.
I like the side of the car, but I don't necessarily like the whole car.
I find it strange that the floor, which in theory is the most important element of this formula looks so simple. Of course they could hide things, but we are less that 18 hours before the very first test of the season.
Even AR, or AT have a much more developed floor. I really hope they hide the floor, because from what we saw so far they, probably, have some catch up work to do!
