2024 Pre-Season Testing - Bahrain International Circuit, Feb 21 - 23
Dream Theater
21
Re: 2024 Pre-Season Testing - Bahrain International Circuit, Feb 21 - 23
zeroday wrote:
22 Feb 2024, 00:31
deadhead wrote:
21 Feb 2024, 19:59
The engineers at the other top teams might as well go home
ngl, based on every other teams contributions these past two years. I dont think they ever came to work in the first place. it's the only way to explain this dramatic disparity. :lol:
Thousands of degree-holding engineers versus one old guy. Goes to show, getting a degree means nothing in life. The only way to achieve great things is to have passion & love for what you're doing, not a piece of paper saying you memorized words really well (ie. school degree). Hats off to Newey.
Newey proves that in his cars, clearly anyone, even Mazepin, can be a world champion. =D> =D> =D>
I replied to a very similarly-ignorant comment on the 2024 pecking order thread. You guys need to elevate your way of thinking, really. Clearly you never worked on a competitive tech environment.
Also, yeah, let's pretend a guy called Pierre Wachè doesn´t exist.
dialtone
dialtone
121
F1Krof wrote:
22 Feb 2024, 00:47
I have a hunch that the reason why nobody can match RBR is due to their suspension. They must have found a trick in there.
Unlikely at this point. Nobody is porpoising anymore. They are ahead because everyone else spent the last 2 seasons preventing porpoising and instead their suspension+floor back then was already good enough to avoid it so they focused on everything else and have been good at it.
mendis
mendis
19
Oehrly wrote:
21 Feb 2024, 20:06
Hi everybody, it's time for timing data.
Due to popular request, here is the link to the apparently "traditional" Google Sheet with all timing data for the whole day.
(Not sure if anybody else makes these as well by now)
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Please do a bit of a sanity check when using the data. I'm a bit short on time and just quickly tried to bend my upload script into submission, persuaded google to use the correct data types and hope everything is good now.
Day 2 and Day 3 will be added to the currently empty worksheets.
The sheets for 2023 and 2022 are linked in the document as well, if you want to compare.
It should be possible to properly filter and sort all columns by drivers, lap times and so on.
And if you want, you might of course add the link to the opening post so it doesn't get lost as easily.
Isn't this @f1debrief's work? Here is the link.
https://twitter.com/f1debrief/status/17 ... 887122398
dialtone
dialtone
121
mendis wrote:
22 Feb 2024, 03:26
You are responding to the author of the python fastf1 library that everyone uses to draw fancy graph with f1 data, probably f1debrief too.
mendis
mendis
19
dialtone wrote:
22 Feb 2024, 04:03
mendis wrote:
22 Feb 2024, 03:26
My apologies if that's the case. I wasn't aware! Thanks for the info.
DAMNINice
37
chrisc90 wrote:
21 Feb 2024, 22:04
https://i.ibb.co/B4xqp4y/Screenshot-202 ... 200347.png
interesting comparison.
Very interesting.
Let's assume he was pushing more in qualy in risky high speed corners. That's where he was losing time compared to 2023. BUT.... very interestingly... he gained nearly 1 sec in slow speed corners (esp. the braking zones) with the new car. That's crazy. :shock:
REal men play with twins!
DAMNINice wrote:
22 Feb 2024, 08:09
chrisc90 wrote:
21 Feb 2024, 22:04
Very interesting.
Let's assume he was pushing more in qualy in risky high speed corners. That's where he was losing time compared to 2023. BUT.... very interestingly... he gained nearly 1 sec in slow speed corners with the new car. That's crazy. :shock:
It is the area they wanted to improve most over 2023
DAMNINice wrote:
22 Feb 2024, 08:09
Very interesting.
These dips in slow speed corners followed by a rise and leaving the difference where it was before braking indicates a difference in braking point. Unfortunately, the track is still dirty so there are external influences hampering performance of every car compared to 2023 Q session.
FittingMechanics
FittingMechanics
16
Ted Kravitz - you don't need a white visible layer of sun protection cream for it to work.
CaribouBread
CaribouBread
101
FittingMechanics wrote:
22 Feb 2024, 09:03
Might be the clown makeup he forgot to clean properly :shock: :mrgreen:
jambuka
jambuka
F1Tv should really have onboard cams for testing.
dialtone
dialtone
121
That LEC lap was great.
The RB is on fire
No.. literally this time
CaribouBread
CaribouBread
101
Looked tidier than any run yesterday for sure
jambuka
jambuka
dialtone wrote:
22 Feb 2024, 09:25
Yeah, car still didn't look agile though. Much settled.
