470
Re: Ferrari Power Unit
piast9 wrote:
Silent Storm wrote:http://www.f1analisitecnica.com/2017/02 ... -2017.html
- energy recovery from MGU-K will be less than in 2016 because of shorter braking time, therefore MGU-H will become more important
I don't get it. The braking time will be reduced but the braking power will increase as the total braking energy will remain unchanged or even increase because of higher speeds and larger weight.
But the MGUK portion of the braking power will remain at 120kW.
piast9
piast9
wuzak wrote:But the MGUK portion of the braking power will remain at 120kW.
Oh... I thought it was the limit for the MGUH only. Now I got it, thanks.
FrukostScones
163
Ferrari PU 2017 is powerful.
hurril
hurril
FrukostScones wrote:Ferrari PU 2017 is powerful.
Ok.
FrukostScones
163
Ok.
http://www.f1today.net/en/live/f1/22267 ... st-of-2017
Driver Max speed (speed trap, not top speed)
1. Vettel 283.4 0
2. Hamilton 280.5 0
3. Massa 280.5 0
4. Magnussen 278.3 0
5. Ricciardo 276.9 0
6. Hülkenberg 276.9 0
7. Bottas 276.2 0
8. Sainz jr 273.4 0
9. Perez 270.6 0
10. Alonso 270 0
11. Ericsson 0 0
Nobody is running flat out. Merc were running rev limiters set early all morning.
FrukostScones
163
PhillipM wrote:Nobody is running flat out. Merc were running rev limiters set early all morning.
and Honda too :lol:
(btw that explains maybe why BOT was so much slower than HAM)
Juzh
161
That's a fact?
Cold Fussion
Cold Fussion
93
Even if the MGU-K wasn't limited to 120 kW, it would still probably lower because of the lower top speeds and reduced speed lost from higher cornering speeds.
FW17
171
New Ferrari engine 5kgs heavier to make through the season with 4 PUs
--TED
Silent Storm
Silent Storm
122
FW17 wrote:New Ferrari engine 5kgs heavier to make through the season with 4 PUs
--TED
Andy Cowell has said Merc PU is also heavier giving the same reason.
Brian Coat
Brian Coat
99
Unless I misunderstand, this would imply them both being above the regulated minimum engine weight?
Everyone believe that?
seezung
seezung
56
Ferrari evaluating radical 'double anchor' injector idea
https://www.motorsport.com/f1/news/ferr ... ea-879930/
BosF1
BosF1
Sounds promising if they get it to work!
