Paa wrote: ↑30 Aug 2024, 11:55
I think straight line speed/drs advantage is gone. They are best equal with some other teams.
The only slight advantage they have is in the fast sweeping corners (as long as track is smooth). So they will be probably good in parabolica. But generally there is much more time can be gained/lost in the chicanes.
Was similar in Spa through sector 2. More wing level than other (presumably to protect the tyre deg?) but didn’t help on the DRS zone after eau rouge.
If the DRS has been lengthened 105m here, the DRS advantage will be huge.
A higher wing to gain a big on the higher DF sectors, will mean your a sitting --- on a long straight with little chance to defend
