Big Gun wrote:
31 Aug 2024, 17:50
KimiRai wrote:
31 Aug 2024, 16:38
FNTC wrote:
31 Aug 2024, 16:25
Was there a yellow flag on his last attempt? Colapinto went wide into the gravel just before I think?
Yes yellow flag for Lance, unlucky. Not sure how his lap was.
Q3 is not going to happen unless Alonso pulls a massive lap
Still Alonso didnt get to finsih his second run in Q1, 1st run Lance was 4 tenths slower, dunno how the Yellow effected them.
Alonso abandoned his 2nd run in Q1 cause he was told that he was through to the next round.
FNTC wrote:
31 Aug 2024, 18:38
https://preview.redd.it/italian-gp-qual ... 07118e99ca
https://preview.redd.it/italian-gp-qual ... 7f824487a3
Hmm, took off some downforce? Maybe some chance of overtakes tomorrow? Fastest top speed and largest DRS delta.
Maybe they turned the PU up.
xReVo
xReVo
SSJ4 wrote:
31 Aug 2024, 22:27
Upgrades or just changing some components?
Updates impossible, they would have already tested them in free practice. They are changing some PU components
-wkst-
-wkst-
Outlap in Q2 was badly timed in my opinion. Only got a huge tow from PIA into the first corner and maybe a bit from the Haas drivers out of 1, but absolutely no tow afterwards…
search
xReVo wrote:
01 Sep 2024, 04:56
the engine is/was new, though. Are they going to save it because points are out of reach anyway? ;)
peewon
SSJ4 wrote:
31 Aug 2024, 22:27
Cant be updates since parc ferme. Unless they plan on taking penalties. Probably some safety concern due to chance of failure. Unexpected as unless Im mistaken, it was a new PU.
search
There are no replacements mentioned in the FIA document:
https://www.fia.com/sites/default/files ... %C3%A9.pdf
would a different engine be listed in there at all, though?
edit: apparently yes, going by the Austria report: https://www.fia.com/sites/default/files ... %C3%A9.pdf
peewon wrote:
01 Sep 2024, 12:39
SSJ4 wrote:
31 Aug 2024, 22:27
You can change parts for same parts, changing to different parts would require starting from pit lane. So you could change a floor for new same floor, replace a PU with newer PU, as long as your withing the number of PUs allocated. Or you can change one of the 5 or 6 different sections of the PU. There is a bunch of other stuff like seals and stuff you can change if need be.
Rikrikrik
Rikrikrik
I will confess here. The pace in this race is absolutely more competitive ( not enought of course) than i was thinking
SSJ4
SSJ4
Why did we pit so early. So stupid. A long way to go on hards
TLof
TLof
Both are doing a 2-stop
Kamel
Kamel
DRS not working
SSJ4
SSJ4
Is the plank on fire or burning or was I seeing something
SSJ4
SSJ4
Such a stupid strategy. Would have had a clear p9
TLof
TLof
Great drive. But still no points. Unbelievable
