AR3-GP wrote: ↑01 Sep 2024, 21:10
Red Bull doesn't have time or budget to invest in a wing that works for 1 or 2 races when there are bigger questions about the car concept that need to be solved. Is this not obvious?
I understand the reasoning, but I disagree with its premise. Vegas will be the same thing, meaning they compromise two races knowingly. A Monza wing could have been done with 1 iteration, just copy Ferrari's wing and adapt the wing tips to existing endplates etc. They had to go through the trouble of designing a set of flaps for front wing in any case, so a few cases of CFD runs and maybe even a few WT runs had to be done for this spec. There is absolutely no performance engineering logic in their decision not to make a new wing and use it in at least 4 races, Monza and Vegas 24 and 25. Costs for a rear wing are quite low and they are by far the lowest for this spec, as tools are the smallest, machining time is shortest and loads are smallest so you need the least amount of materials too
