LEC showed last year that when you dump in as much fuel as you want disregarding the fuel regulations you can rack up pole positions and overtake cars of "similar speed"Moore77 wrote: ↑30 Nov 2020, 16:43Leclerc showed last year that, even with cars of similar speed, you can overtake, if you drive better. There are abundant incidents where cars with half a second per lap pace advantage can overtake in Sakhir. Even there are examples of similarly matched cars, like Ricciardo showed yesterday, you can overtake. With 4 seconds per lap advantage, you can lap the entire field.
Plus the Alfa Romeo had front wing damage!LM10 wrote: ↑30 Nov 2020, 16:20Bottas has never been good on race pace, following and pressurizing a car in front or wheel to wheel fight. He’s driving the (by far) fastest car on the grid and fastest car in F1 history, yet struggles to overtake an Alfa Romeo for several laps, one of the slowest 3 cars with a 40-50 hp down on power engine.
If he can’t manage to come close enough to this dog of car in his W11, then there is no argument left for his race pace abilities really.
https://www.motorsport.com/f1/news/why- ... n=widget-1He took a set of mediums at his stop on lap 25, and then pitted again on lap 38.
Rather than go to the unfavoured softs, the team took the opportunity to re-fit the medium set that he had run in qualifying and at the start of the race, but without the punctured right front – and thus he kept the well-used tyre that was already on that corner.
The terminal posts should be solidly mounted (the start and end), the posts in between shouldn’t.
How strange, but at least it would explain some lack of pace. Why not use hards? None left?MtthsMlw wrote: ↑30 Nov 2020, 17:27https://www.motorsport.com/f1/news/why- ... n=widget-1He took a set of mediums at his stop on lap 25, and then pitted again on lap 38.
I noticed during the race one of the drivers was making 4 different adjustments for a corner.Moore77 wrote: ↑30 Nov 2020, 16:52Those were the days of heavy reliance on front wing when Mercedes used to struggle in traffic. In last couple of years, with simplified front wing and more durable tyres (less susceptible to thermal degradation from wake), Hamilton has shown upteen number of times how to chase and kill, without any issues. So car's setup is not such an issue. Especially on Sakhir where following is so easy from the last corner.Phil wrote: ↑30 Nov 2020, 16:44And I'm saying, there are set up considerations to consider. They don't set up the Mercedes to drive in traffic - it's setup for the high probability of it driving in clean air at the front, maximizing lap time over high speed on the straights. Factor cooling into that, as well as overall downforce. Bottas got himself into traffic in a DRS train of other cars with similar or better top speeds. It really isn't rocket science.
Why should car adjustments be removed? It differentiates between drivers, giving better ones an advantage. They dont heel-toe any more, and don't manually shift the gear lever any more, the adjustments give them something to do. And yes, as a spectator I ENJOY IT.Big Tea wrote: ↑30 Nov 2020, 18:45I noticed during the race one of the drivers was making 4 different adjustments for a corner.Moore77 wrote: ↑30 Nov 2020, 16:52Those were the days of heavy reliance on front wing when Mercedes used to struggle in traffic. In last couple of years, with simplified front wing and more durable tyres (less susceptible to thermal degradation from wake), Hamilton has shown upteen number of times how to chase and kill, without any issues. So car's setup is not such an issue. Especially on Sakhir where following is so easy from the last corner.Phil wrote: ↑30 Nov 2020, 16:44
Well, I say I noticed, I did not, it was the commentary by 2 ex drivers who mentioned it.
This is a possible area that makes no difference to spectators which could be removed, and the car set up for the whole lap. We may then see some cars better on one type of corner and another car or driver on a different corner and they may be able to overtake.
This combined with the trend to modify corners so cars go as fast as possible is removing the cornering component from drivers. Tighter sharper corners that need to be driven round could increase lap and reduce the trafic jams in the race and qualli where there is no space to pick your position for a qualli lap cos the cars come around too soon.
I fully disagree.Big Tea wrote: ↑30 Nov 2020, 18:45I noticed during the race one of the drivers was making 4 different adjustments for a corner.Moore77 wrote: ↑30 Nov 2020, 16:52Those were the days of heavy reliance on front wing when Mercedes used to struggle in traffic. In last couple of years, with simplified front wing and more durable tyres (less susceptible to thermal degradation from wake), Hamilton has shown upteen number of times how to chase and kill, without any issues. So car's setup is not such an issue. Especially on Sakhir where following is so easy from the last corner.Phil wrote: ↑30 Nov 2020, 16:44
Exactly.Mudflap wrote: ↑30 Nov 2020, 19:17I fully disagree.Big Tea wrote: ↑30 Nov 2020, 18:45I noticed during the race one of the drivers was making 4 different adjustments for a corner.Moore77 wrote: ↑30 Nov 2020, 16:52Those were the days of heavy reliance on front wing when Mercedes used to struggle in traffic. In last couple of years, with simplified front wing and more durable tyres (less susceptible to thermal degradation from wake), Hamilton has shown upteen number of times how to chase and kill, without any issues. So car's setup is not such an issue. Especially on Sakhir where following is so easy from the last corner.
The more the driver has to do in the cockpit the higher the skill required.
That's why traction control is banned even though it makes no difference to most spectators..
Respecfully, I fully disagree with your disagreement. There are many skills I, and in my opinion most F1 fans, value. Natural feel, courage, quick reflexes, and even, in rare cases, tyre saving. The ability to multi-task, however, is not one of those.
But is this any 'entertainment' to the watcher? It is a skill no doubt, but is it a driving skill? once established it is 'just' a matter of flicking a thumb to to a preset number every time, and I have little doubt that number was established, if not by, then defiantly with the help of, an engineer looking at data. Yes it is part of racing, but it is [art of what is making overtakes almost impossible. It is almost akin to movable aero in that it altered the characteristics of the car in different parts of the track.Mudflap wrote: ↑30 Nov 2020, 19:17I fully disagree.Big Tea wrote: ↑30 Nov 2020, 18:45I noticed during the race one of the drivers was making 4 different adjustments for a corner.Moore77 wrote: ↑30 Nov 2020, 16:52Those were the days of heavy reliance on front wing when Mercedes used to struggle in traffic. In last couple of years, with simplified front wing and more durable tyres (less susceptible to thermal degradation from wake), Hamilton has shown upteen number of times how to chase and kill, without any issues. So car's setup is not such an issue. Especially on Sakhir where following is so easy from the last corner.
A penalty? A racing ban? Everyone is happy that he is still alive, because that is a very great miracle and then you start talking about a race ban? <>
Definitely. He praised Hulk for his super-sub moment earlier in the year.jjn9128 wrote: ↑30 Nov 2020, 13:24I think max is on the record that he wants Hulk in the other car.zibby43 wrote: ↑30 Nov 2020, 11:02Max went straight savage on Albon after the race.
Completely unsolicited, too.
Interviewer: “Good thing that Alex takes the podium and score some good points.”
Max: “Well yeah, that’s your conclusion but if you trail your teammate with 30-40 seconds you can hardly say he did a good job. Still nice for Alex to score a podium though.”
Yikes.
