PlatinumZealot wrote: ↑08 Mar 2020, 23:37
The FIA, if they hire the appropriate experts, should be able to measure the speeds of sound, possibly DENSITYin the declared fuels and mixtures of them as they flow through the meter. This is possible because the flow meters have that function. The accuracy of this function is of course something else to find out.
They can do all of this before the race using something like Anton Paar DMA 5000.
It is hoewer affected by inter molecule associations or molecule dissociations depending on temperature and pressure.
Once again, within the chemistry permitted by the regs (i.e., mostly hydrocarbon fuel, with only small amount of oxygen and nitrogen-containing compounds, and even less metals) the different fuel blends will behave close to an ideal solution, which means the properties of say 50/50 m/m mixture is right between the initial fuels.
So I don't know where to gain anything.
The flow meter only registers at the the denser volume..
The flow meters are ultrasonic, they should be able to determine the speed of sound and thus the density, so they should be immune to alterations of density.
If they aren't then I'm sure everybody will be doing this.
If FIA put the right personel in place they can measure the desnity of the fuel "in-situ."
They can measure the speed of spound too.
They take fuel samples after the race. The density and speed of sound measurement is a routine one.
Yeah, and I raised this point before -- if the "trick" involved something to do with the fuel, why the power advantage was only apparent during Q3 and the first lap of the race?
