dans79 wrote:jz11 wrote:
it is not so easy to adjust that max fuel flow and maintain some sort of performance from the car, surely they gained some advantage over the competition by doing so, but calling them cheats - never, its just dumb, the base rule still is - 100kg/h, which they claim not to have exceeded and FIA, the POLICE, say they did, based on a wacky flow meter
Well it can't be that hard, considering every other team on the grid did it.
they did cheat considering it's come to light that they received a technical directive march 1st that told them the sensor readings are the only thing that mattered.
calling that cheating would be like calling someone dumb just because someone, who you KNOW has lied before, said so, these things are relative, and should have (and in this case - could have) been avoided at all cost
and remember that pretty much every other team had quite a bit more time testing their cars, didn't they? so maybe they just didn't have enough time to investigate this and develop a solution
IMHO they, RB, did what they had to do to try and get the best result out of this particular GP, I don't believe they would have cheated so bluntly
I'm more puzzled about why FIA didn't homologate engines (or rather whole PU) with certain engine maps (dry/wet/w-wet for instance) that they know cannot exceed the 100kg/h limit, similar to the old V8s, that were tied to certain power output characteristics, and then use that not-too-accurate flow meter just to eavesdrop on the situation, or to measure the 100kg limit for the race, and if someone is suspected of cheating - investigate that
