Nose still looking suspicious
Yes, that panel seems too crude... Where is the cockpit vent?
Those are the new for 2024 "hot race" cooling scoops. My suspicion: they are hiding the real nose and that means the regular driver cooling inlet can't be used hence they have to use the extra cooling scoops for testingkediown wrote: ↑21 Feb 2024, 09:24https://pbs.twimg.com/media/GG1-4f4bUAA ... name=large
Is it possible the cooling vent has moved to there?
f1rules wrote: ↑16 Feb 2024, 09:49Ok im completely out on a limp here. Could they open up the panel shown by jagunx51, just next to/behind the halo and let air in for to move the flow to a more desired location, the central diffuser, and combined with scarbs drawing, maybe they exit the vertical inlet flow there also. Could there be advantages in mixing those two, would the upper help pull the air from below faster?
I borrowed jagunx51's picture and artwork done by
Craig Scarborough
@ScarbsTech
https://pbs.twimg.com/media/GGcTYHgWQAA ... ame=medium
