raymondu999 wrote:Is their main plane almost designed to generate lift when DRS is activated? Looks from that angel as if the trailing edge is some bit lower than the leading edge.
In the picture it is hard to tell, but the black band at the trailing edge of the main plane reminds me of a gurney flap. I don't recall if such a thing is a allowed, or even advised as it would disrupt flow through to the upper plane.
Edit: After much closer inspection of the angle between the trailing edge and the centerline strake, that black band is just livery. No gurney flap.
