CAEdevice wrote:Yes, the first run and the mesh mapping have been done. Theoretically you could launch simplefoam by console, but singlethreaded (my advice is to wait for Julien's solution).
Could you look for the log in the models (upper) folder?
I got the same error with paraview version 3.98.1
so i'll post the log file
here's what I found
Create time
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file MSwindows.C at line 1314
dlopen error : "Error 126: The specified module could not be found.
--> FOAM Warning :
From function dlLibraryTable::open(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 100
could not load "libsimpleSwakFunctionObjects.so"
--> FOAM Warning :
--> FOAM Warning :
could not load "libswakFunctionObjects.so"
--> FOAM Warning :
--> FOAM Warning :
could not load "libsimpleFunctionObjects.so"
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Reconstructing fields for mesh region0
Time = 500
Reconstructing FV fields
Reconstructing volScalarFields
nut
ptot
p
k
y
omega
yPlus
Reconstructing volVectorFields
wallShearStress
U
Reconstructing point fields
No point fields
No lagrangian fields
Reconstructing sets:
End.
any ideas?
