You're thinking similarly to what i'm thinking, "air skirts".manchild wrote:I think Scarbs' explanation is ok as far as it considers approximate position but nothing further than that. No pun intended, just my thoughts.
Orange temperature stickers are glued exactly where he said that the exhaust pipe is pointed out. I think that if that would be the case than whole area would be covered with heat resistant material rather than painted.
What I think is that stickers are glued to a tunnel which no one mentioned. There is clearly a tunel or a pipe, call it whatever you want - a space around the exhaust pipe to enable entrance of air in order to cool the exhaust. Its exit can be seen where sidepods end (boxy shape).
I still claim that exhaust pipe isn't reaching all the way, isn't pointed forward, but bended to blow into several tiny tunels sculptured on top of the floor, which than distribute the gasses below the car to create virtual skirts, and above the floor to generate more downforce as they hit the lip of the floor bent upwards, as well as to aid virtual skirts below the floor as they travel over undercut and floor's longitudinal edge.
The sideways nature of the pipes and the turning vane support the idea more.
The last tests will be interesting if Renault decide to go all out with their ground effect car.
