FLC wrote:jason.parker.86 wrote:I have a sneaky feeling that the McLaren has some new tripple decker diffuser! Although it is covered up - looks too big to be a double decker.
Are there any disadvantages to using the triple decker or is it just packaging and layout of components?
Yup, Toyota found that out, early season when all but Brawn and Williams had the DDD they didnt have much of a disadvantage, but by Turkey they had to change it back to a version of the DDD they tested last in pre season.
The Triple Deck has implications on drag, not for the car its self, but for the car following, Toyota found out that the Triple Decker could help certain cars punch thrugh the hole a little better and overtake them.
Best solution is the Double Deck version, as it provides more downforce to its drag ratio seemingly. A aero guy could better explain the consept better.
Personally id like to see the SDDs back, but allowable to be a steeper angle, not the 175mm high that they cuurrently are allowed, but to 200mm But id make the diffuser only have a maximum of 2 vaynes per side and the centre section to drop down to the current 175mm size to allow therear crash structure to come out.
