Chalke wrote:Aside from the exhaust slots, also now visible on this pic are a new monkey-seat, reduced size engine cover exit and an all-around slot on the diffuser edge.
The small wing attached to the beam wing is the monkey seat.forty-two wrote:Chalke wrote:Aside from the exhaust slots, also now visible on this pic are a new monkey-seat, reduced size engine cover exit and an all-around slot on the diffuser edge.
Sorry, but what do you mean by "Monkey-Seat"?
Downloads are unlimited but are also subject to our "Acceptible Use Policy".raymondu999 wrote: I'm not sure it can download much; but it will add a bit of downforce
I'm not sure I'm seeing what you're seeing there. Where or what do you see?Crucial_Xtreme wrote:What's this in the exhaust area? Curious. right click>view image
Don't forget to read the EULA so you're not signing over your firstbornforty-two wrote:Downloads are unlimited but are also subject to our "Acceptible Use Policy".raymondu999 wrote: I'm not sure it can download much; but it will add a bit of downforce
Which part are you speaking of?officialsushy wrote:
will this be legal.Mclaren can use smaller version of it.i mean would there be difference by putting it up high or low
I believe I'm wrong. I thought it looked like they were using a different exhaust fairing. I don't think so now. :/forty-two wrote:I'm not sure I'm seeing what you're seeing there. Where or what do you see?Crucial_Xtreme wrote:What's this in the exhaust area? Curious. right click>view image
raymondu999 wrote:Don't forget to read the EULA so you're not signing over your firstbornforty-two wrote:Downloads are unlimited but are also subject to our "Acceptible Use Policy".raymondu999 wrote: I'm not sure it can download much; but it will add a bit of downforce
It can in the central 150mm which are not regulated, thus allowing extensions like on the McLaren.officialsushy wrote:I was speaking beam wing.can it be low or high
thanksGusgus wrote:It can in the central 150mm which are not regulated, thus allowing extensions like on the McLaren.officialsushy wrote:I was speaking beam wing.can it be low or high
