raymondu999 wrote:Setup is the biggest question for me. I wonder if the low drag setup philosophy of Monza is true anymore.
Watch back to 2011, and Vettel was the fastest car bar none through Curva Grande, as he had better traction onto the straight, and was hitting his top speed (while others couldn't hit even Vettel's top speed)
I think part of this was RBR`s philosophy in regards of using EBD to generate the downforce.
I think the short gearing played into this, I don't thing that they run an "extremely draggy" wing configuration their last year, but they surprised people with their gear ratio choice.
I will depend a lot on how you finish (or what your expectations are) for Qualifying and if you feel, you can make a "break" early from the field and don't be exposed to an DRS attack.
With EBD not being such an dominant factor (the effect is still there, but not as strong as last year) , they may need to rethink their approach a bit, will be interesting to see, which route the different teams choose.
On a side note, what the weather forecast like? Any chance of a wet race?
