Force India VJM07 Mercedes
Re: Force India VJM07 Mercedes
@JDC123: A few Pieces this Week, but the the last 2 Days of next Weeks Testing should bring a lot of new Stuff.
Winter Testing 2014 - Session 2, Day 2 - Bahrain (20.02.2014)
Blanchimont
Blanchimont
214
From the current AMUS gallery
michl420
michl420
Because of this picture scarbs assume that the second inlet is the engine air intake, but this brings us to one problem !
5.14.1 With the exception of incidental leakage through joints or cooling ducts in the inlet system (either into or out of the system), all air entering the engine must enter the bodywork through a maximum of two inlets which are located :
a) Between the front of the cockpit entry template and a point 500mm forward of the rear wheel centre line longitudinally.
b) No less than 200mm above the reference plane vertically.
c) On vertical cross-sections normal to the car centre line.
Furthermore, any such inlets must be visible in their entirety when viewed from the front of the car and without the driver seated in the car.
Winter Testing 2014 - Session 2, Day 4 - Bahrain (22.02.2014)
maheshvi
maheshvi
Did anyone noticed the asymmetrical rear view mirror? What is that bulge on the right rear view mirror for?
JackHammer
maheshvi wrote:Did anyone noticed the asymmetrical rear view mirror? What is that bulge on the right rear view mirror for?
Sensor/camera
From memory I believe Force India have ran the same thing on the mirror for the past few years in testing
232
Blanchimont wrote:From the current AMUS gallery
http://img2.auto-motor-und-sport.de/For ... 756601.jpg
You can see here that the fuel tanks are really much smaller compared to last year.
Notice how much narrow it is.
As for the Intercoolers, they must be on the right side of the car. As it seems only the radiators are on the left side.
Matt Somers
Matt Somers
179
Probably already seen/mentioned but:
https://twitter.com/SomersF1/status/438604237216296960
Winter Testing 2014 - Session 3, Day 1 - Bahrain (27.02.2014)
FrukostScones
163
I really like the design of this car and also the livery is kind of good. I hope it will be quick and give McLaren and Mercedes a headache.
Sebp
http://twitter.com/ScarbsF1/status/439416683225051136 Has anyone noticed other teams doing the same?
No smartphone was involved in creating this message.
Owen.C93
Owen.C93
177
I thought it was common, it's what those cooling slots utilize. It's just narrower now because of the smaller fuel tank.
Sebp
For some reason I always thought those were connected to the sidepods. :? :?:
Godius
186
Godius wrote:The rendering showcased outlet gills on top of the side pods, the Jerez version of the chassis doesn't have those things fitted:
racecar-engineering
The car was sporting these outlet grills on the side pods today:
