I wouldn't be so sure. This track seems to favor the Ferrari for whatever reason, they can work the tires better than Mercedes can. If Mercedes doesn't have at least a .7 second advantage per lap or higher, then it's simply going to be a race of who makes the least mistakes.dren wrote:Mercedes will fix their starts and drive off to the win, they will manage Ferrari all the way to the end. Toro Rosso will be the best of the rest.
This week therefore, teams on the Strategy Group and F1 Commission found themselves only able to vote on a revised format to elimination qualifying proposed by the FIA, where the new-style Q1 and Q2 would be extended, and Q3 would revert to how it was last year.
However, if that was a motivation for not giving teams the option of going back to last year’s system, then it failed entirely because McLaren and Red Bull refused to support it and did not vote in favour.
Without their support, the vote did not go through, meaning that F1 is heading to Bahrain with the same under-fire elimination qualifying format that was run in Australia – and little prospect of it delivering a better show in Q3 this time.
you never give up do you? in 2015 Mercedes had 2 TWO DNFs due to engine mechanical fault Ferrari had 1 ONE DNF due to engine mechanical fault. you can try to twist that any way you want. those are the facts.GPR-A wrote:Which planet do you and your kind come from?A-Bap wrote:Exactly!...Because Mercedes has never cared about learning from their mistakes...and we all know they have severe reliability problems. Sure they ran the equivalent of a full season's worth of race distances during winter testing...with hardly a burp....but really, what does that prove?Chene_Mostert wrote:
Anyway getting back on topic.
Mercedes will not be let off easy this time.
Again they will cock up the start but this time Ferrari will not make a strategy mistake.
One Merc will retire from the race.
Looking forward to all the GPRA calculations showing Merc should have / could have won the race, but they never showed their pace, kept those 2sec per lap back by carrying bags of sand. Why?
2014
Retirements - Mercedes 5 - Ferrari 3
PU Usage (Two drivers) - Mercedes ICE 8, TC 8, MGU-H 8, ES 6, CE 8, --- Ferrari ICE 10, TC 9, MGU-H 10, ES 8, CE 10
Results - Mercedes Poles 18, Wins 16 - Ferrari Poles 0, Wins 0
2015
Retirements - Mercedes 2, Ferrari 6
PU Usage (Two drivers) - Mercedes ICE 8, TC 8, MGU-H 8, ES 6, CE 8, --- Ferrari ICE 11, TC 9, MGU-H 9, ES 9, CE 9
Results - Mercedes Poles 18, Wins 16 - Ferrari Poles 1, Wins 3
2016 (Counting)
Retirements - Mercedes 0, Ferrari 1
Results - Mercedes Poles 1, Wins 1 - Ferrari Poles 0, Wins 0
I ment this - https://en.wikipedia.org/wiki/Dual-clutch_transmission Or did they use only one clutch?PlatinumZealot wrote:Yes the clutches are all multi plates.. but the controls were two paddles, that had two stages of maximum "clutch bite" that the driver selects in sequence to get a nice soft launch that wont impart too much wheels spin. First stage has a softer bite and the second stage has a hard bite.santos wrote:Double clutch? Don't they use a clutch with multi plates in F1 cars?
With the new rule there is only one stage of bite so is not as easy to get a smooth launch. The driver has to "let out" the clutch more carefully now.
I don't remember will have to check. But It could still be single clutch like in the lexus LFA. Single cltuch tends to be lighter but a bit rougher.Mr.G wrote:I ment this - https://en.wikipedia.org/wiki/Dual-clutch_transmission Or did they use only one clutch?PlatinumZealot wrote:Yes the clutches are all multi plates.. but the controls were two paddles, that had two stages of maximum "clutch bite" that the driver selects in sequence to get a nice soft launch that wont impart too much wheels spin. First stage has a softer bite and the second stage has a hard bite.santos wrote:Double clutch? Don't they use a clutch with multi plates in F1 cars?
“I think it’s more or less what we expected,” Kimi Raikkonen, referring to Ferrari’s closeness to Mercedes in the race, is quoted by El Confidencial.GPR-A wrote:Thanks for keeping faith in me.Chene_Mostert wrote:Anyway getting back on topic.GPR-A wrote:Once again, Ferrari would be unable to show their true pace, as the farce set to continue.![]()
F1 forced to keep elimination qualifying for Bahrain GP
Looking forward to all the GPRA calculations showing Merc should have / could have won the race, but they never showed their pace, kept those 2sec per lap back by carrying bags of sand. Why?![]()
Another idiot agrees with me on your statement.
Should someone with an agenda be trusted?giantfan10 wrote: hmmm do i trust Marko who always has an agenda or do i trust 2 drivers?
funnydans79 wrote:Should someone with an agenda be trusted?giantfan10 wrote: hmmm do i trust Marko who always has an agenda or do i trust 2 drivers?
Hmmm, that sounds like someone else I know!
No...giantfan10 wrote: are you also aligned with the idea that Mercedes can lap the field if they want to? sheesh thats a lot of sandbags
They don´t use double clutch transmissions. Compared to DCT´s they are lighter, faster and smaller volume.PlatinumZealot wrote:I don't remember will have to check. But It could still be single clutch like in the lexus LFA. Single cltuch tends to be lighter but a bit rougher.Mr.G wrote:I ment this - https://en.wikipedia.org/wiki/Dual-clutch_transmission Or did they use only one clutch?PlatinumZealot wrote:
The dual clutches with their two input shafts and two cltuches are smoother... Probably faster shift but much heavier. The weight might offset the slightly faster shift i think.
Are you suggesting that Ferrari was more reliable than Mercedes in 2015?giantfan10 wrote:you never give up do you? in 2015 Mercedes had 2 TWO DNFs due to engine mechanical fault Ferrari had 1 ONE DNF due to engine mechanical fault. you can try to twist that any way you want. those are the facts.GPR-A wrote:Which planet do you and your kind come from?A-Bap wrote:
2014
2015
2016 (Counting)
you can now carry on telling everyone how many wins mercedes had and how many seconds they won by or whatever spin you want to put on it
Me, giving up? No way. The point is, Ferrari manufactured parts that, besides being behind on performance level,THEY CLEARLY KNEW wouldn't last as long and hence kept changing. Look at the PU usage. THAT IS HOW reliability is looked at. Not through whims and fancies.giantfan10 wrote:you never give up do you? in 2015 Mercedes had 2 TWO DNFs due to engine mechanical fault Ferrari had 1 ONE DNF due to engine mechanical fault. you can try to twist that any way you want. those are the facts.
