2022 United States Grand Prix - COTA, Oct 21 - 23
chrisc90
Re: 2022 United States Grand Prix - COTA, Oct 21 - 23
Tvetovnato wrote:
21 Oct 2022, 21:11
Why do they need to red flag a session as soon as someone puts a wheel off track nowadays? Hugely annoying, what a waste of time.
Does seem a bit silly. Red come out when car stuck in barrier. Probably could have been under local double waved yellow.
Swed3121
Swed3121
So far it seems that indycar is quite a bit above F2
5-place penalty
search
Verstappen completely ruined Shwartzman's lap there by dangling on the racing line
chrisc90
search wrote:
21 Oct 2022, 22:00
To be truthful....Max was starting a timed lap.
dans79
267
search wrote:
21 Oct 2022, 22:00
I saw that!
201 105 104 9 9 7
search wrote:
21 Oct 2022, 22:00
At what point in the session? Just before they passed the chequered flag or a bit earlier?
If it was just before passing the chequered flag, max was given a late warning by his engineer
Duchessa reports that the bumps are similarly bad as 2021. So that means the ride heights will be compromised, as in spa
Mogster
21 Oct 2022, 22:17
Easy win for Red Bull then.
Mchamilton
Mchamilton
21 Oct 2022, 22:17
Bump between turn 1 and 2 nearly wiped Hamilton out at one point
Mchamilton wrote:
21 Oct 2022, 23:26
21 Oct 2022, 22:17
Ocon also had a huge moment in a similar place.
Sainz lost bodywork around the rear caketin in sector 1 also
InsaneX_Badger
Didn't they rush the foundations below the track surface, leading to the bumps forming everywhere?
InsaneX_Badger wrote:
21 Oct 2022, 23:43
Yes I believe that is true. When building the track they went cheap and quick, fundamentally installing an insufficient drainage system and this has caused many problems over the years.
Here's a link to a comment who seems to be aware of many of the issues with the track's construction
search
so, will we get to see a Leclerc-Ricciardo-Bottas-Latifi 1-2-3-4 in FP2?
Everyone else in random order, based on which tyres they get
chrisc90
FP2 dedicated to the Pirelli tyre test...no sidewall markings.
Seems a complete waste of a session considering run time is dictated by pirelli, no setup changes, Max Engineer just stater engine mode 6 and NO DRS all session.
