Haas VF-24
Re: Haas VF-24
Another team switching from under to overbite
Front view
Oblique view
KimiRai
KimiRai
298
Re: Haas VF-24
Re: Haas VF-24
Definitely not elegant but it gets the job done.
Huge overbite. Probably the biggest.
CLKGTR
CLKGTR
100
Re: Haas VF-24
Swan neck mounts also look...inovative :D very low, barely going over the top side...almost as they are chopped :?
Usually they connect on the top side high from above to cause less disturbance to the leading edge and low pressure side, but this is some new thinking.
sucof
Re: Haas VF-24
CLKGTR wrote: ↑
06 Jul 2024, 11:05
Hm, with new you mean old? They looked like this before swan necks were introduced.
CLKGTR
CLKGTR
100
Re: Haas VF-24
Off course, but in 'swan neck era' I haven't seen something like this. Maybe because this is a twin support system, not like a single on which goes more over the top.
Better view with DRS actuator on.
dennis h
dennis h
Re: Haas VF-24
Analysis of Haas upgrades :
https://www.gpblog.com/en/news/289167/t ... -haas.html
A lot of things would have to go good for Haas and bad for their competitors...
Farnborough
Farnborough
111
Re: Haas VF-24
That's quite an interesting design of wing support they're using, appears considerably different in flow terms and interpretation to other teams.
I'd bet there'll be other design department looking closely at that, then testing in their own framework.
Farnborough
Farnborough
111
Re: Haas VF-24
Looks like it would fundamentally change sensitivity of yaw characteristic over both surface of rear wing.
Looked pretty effective from the running so far, interesting to see further circuits and on both cars in assessment of gains.
CaribouBread
CaribouBread
101
Re: Haas VF-24
Farnborough wrote: ↑
15 Jul 2024, 13:16
Haven't paid enough attention to haas's rear wing structure, but the connection to the gearbox and the removal of the swan neck is similar to the F175 and early SF23.
KimiRai
KimiRai
298
Re: Haas VF-24
Re: Haas VF-24
Monza rear wing, photo by formu1a.uno. Same one used in Spa, so we may see a flap cutout at some point
SiLo
139
Re: Haas VF-24
Vanja #66 wrote: ↑
29 Aug 2024, 11:15
https://formu1a.uno/wp-content/uploads/ ... _0124.webp
Or just removal of the gurney flap?
Felipe Baby!
Re: Haas VF-24
Latest FW detail and, I think, new sidepod design, photos by motorsport
Also floor detail, not sure if new
Re: Haas VF-24
AMuS
