JB's driving style versus late apex and preserving tyres
Pup
Pup
50
Re: Hamilton aggressive driving style Vs button's smooth dri
Button's problem this weekend was that he was unable to do any long runs in practice due to his transmission problems. He wanted to try a more aggressive setup that would help him get heat into the tires for quallies, so he and his crew had to basically guess at what the log-run wear rate would be.
They guessed wrong (and it didn't help his qually anyway).
raymondu999
Re: JB's driving style versus late apex and preserving tyres
So while people said that JB's smooth rates of transition help keep the tyres in shape, others have said that the way a more aggressive tighter turning circle when the corner last for less time (even though peak singular loading might be more) makes it last longer. So which is it then?
Judging from sheer logic, I'd venture a smooth arc would hurt the tyres under thermal degradation, while a more "squared off" corner will hurt more under wear. The smooth line will hurt the tyre wear less, and the tighter line will degrade thermally less
失败者找理由,成功者找方法
raymondu999
Jo Ramirez on the contrasting styles and car usage of (Alain) Prost vs (Keke) Rosberg
https://soundcloud.com/raymond-umbara/j ... vs-rosberg
失败者找理由,成功者找方法
mariano
mariano
A small correction:
mariano wrote:http://www.turnfast.com/images/tech_dri ... ering2.gif
I think Button's line is the brokenline (geometrical one) and M. Schumacher's, the purple's one.
mariano
mariano
I think Button's line is the purple's one, and M. Schumacher's is the brokenline (geometrical's)'s one.
Actually you've got it the opposite way around :wink:
Yes, I´ve just corrected it.
