2024 Mclaren Formula 1 Team
geogate
geogate
looked pretty decent to me. Mclaren usually run Oscar quite heavy, Lando usually runs fairly typical FP1/FP2 loads - they don't run light
Macklaren
Macklaren
Would be great if Merc could get up there and take some points away from Ferrari
Emag
Emag
109
Macklaren wrote:
21 Jun 2024, 18:16
With how they've been looking, they would be taking points from everyone, not just Ferrari ...
Developer of F1InsightsHub
Emag
Emag
109
There will be more accurate data later, but this one is going around at the moment.
Not bad pace for Lando, clearly he is taking care of his tires on those first couple of laps.
However, I am surprised Oscar is still doing the same mistake of pushing really hard early on. It was the same in Imola, where he was pushing like crazy after pitting but then fell off quite significantly in the end compared to Lando.
You can see how hard the dropoff is for him on this long run after going ~1 second faster than everyone else on that opening lap.
Emag wrote:
21 Jun 2024, 18:38
Maybe deliberate to simulate pushing tyres hard at start of race vs Norris approach of conserving and not fighting as much?
mwillems
45
Yep, looks like two different run profiles to see how the tyres react to different temps through pushing, deciding if they can do a stint on Sunday.
It looks like a 2 stopper for Sunday so softs are in with a shout of being used.
-Bandit
LionsHeart
LionsHeart
Emag wrote:
21 Jun 2024, 18:38
https://pbs.twimg.com/media/GQnBFndWgAE ... ame=large
Even so, everything looks good. But there is a high probability of rain in the race. And that could mess things up. Using high downforce will give an advantage. Let's see if Mercedes has a rear wing in the same Monaco specification.
Density in tempo is good. In the third year of the technical regulations, the teams leveled off in this indicator.
CjC
CjC
Emag wrote:
21 Jun 2024, 17:42
CjC wrote:
21 Jun 2024, 17:41
MrGapes wrote:
21 Jun 2024, 15:20
Saw on Sky Zak mention they do have some new bits on the car... I assume its some weight saving parts because nothing was mentioned in the document.
Tomsky posted this last week so I would have been surprised if there wasn’t any upgrades.
Tomsky wrote:
12 Jun 2024, 12:50
If you read the article, Stella never mentions Spain specifically, he just says over the coming races.
Stella didn’t.
However like Mrgrapes says and I’ve just watched the interview, Zak says there are some upgrades here in Spain.
So…… as nothing was noted on Fridays show and tell the upgrade is either weight saving or something under the bonnet.
I am right in thinking that under the skin upgrades don’t need to be mentioned on Fridays show and tell sheet?
Just a fan's point of view
mwillems
45
LionsHeart wrote:
21 Jun 2024, 18:55
Emag wrote:
21 Jun 2024, 18:38
In the Forecasts I can see, there is about a 5-10% chance of rain once the race is underway, with a higher chance of rain in the morning.
As it stands, it seems to be a dry race. But anything can change.
-Bandit
LionsHeart
LionsHeart
mwillems wrote:
21 Jun 2024, 22:17
LionsHeart wrote:
21 Jun 2024, 18:55
Emag wrote:
21 Jun 2024, 18:38
Thank you very much, comrade. Well, if so, then extra downforce will not hurt. If it rains in the morning, then some rubber will be washed off the road surface, and this can increase tire wear, possibly granulation. Although, to be honest, I do not always understand the conditions for the origin of tire granulation.
mwillems
45
LionsHeart wrote:
21 Jun 2024, 22:40
mwillems wrote:
21 Jun 2024, 22:17
LionsHeart wrote:
21 Jun 2024, 18:55
We ran higher wing in the earlier parts of the season and did very well through the high speed sections. Australia comes to mind.
Spain of course has about 1/3 of the track as long high energy corners. I hope it does rain in the morning. The race will be a little more dramatic with a green track that is evolving.
-Bandit
BMMR61
That "long run" lap chart looks very promising for Lando. It's been a trend since the major upgrade that the team are prioritising tyre preservation - evident in the late race pace Lando has had at at least three of the last five races. This race will be a stern test of Oscar's evolution in tyre management and should provide him and his engineer strong data points on best use tactics.
mwillems
45
A compliment from Helmut Marko.
-Bandit
CjC
CjC
mwillems wrote:
22 Jun 2024, 01:45
I wonder if he said that after knowing what they ‘know’ after FP1 & 2?
mwillems
45
CjC wrote:
22 Jun 2024, 09:48
mwillems wrote:
22 Jun 2024, 01:45
I think it is just a reflection of the fact that we will be in the mix at every track and he sees this as more of a consistent threat for the constructors. He wouldn't feel the same if Perez was delivering, however.
-Bandit
