1. i knowbeelsebob wrote:1) As someone else pointed out, this is 4% relative to what their sensors tell them, not relative to the absolute amount of fuel flowing through it.Juzh wrote:Hes basing 4% innacuracy off of toto wolfs statement that merc ran at 96kg/h to be on the safe side.
2) They asserted "to be on the safe side", which implies that this is more than they thought they needed to correct by.
3) This still doesn't explain where you got the 6% figure from.
It could well be that they ran at 96 to be on the safe side, because they hit 100 when their sensors said 98.5, and they had a lot in hand, so they went under by a substantial amount. Then, 1kg/h of that inaccuracy was caused by their own estimates of how much fuel they were using being 1% out. Then... the FIA sensor is in spec.
2. i know
3. I was just pointing out where djos's 4% came from. I didn't even mention 6% anywhere.
