Red Bull RB19
Re: Red Bull RB19
https://www.formu1a.uno/en/f1-news-red- ... -upgrades/
Bringing more air into the undercut was the target of Newey’s technicians. The compromise reached was to enlarge the inlets towards the sides, while narrowing them down at the same time. This achieves an improved layout that combines cooling demands with aerodynamic ones.
In these F1 cars, equipped with venturi channels, the lower part of the sidepods has become a very delicate area where the Red Bull philosophy has reigned supreme.
The retouching of this area was accompanied by a slight review of the lateral edge of the back, where there are a series of vortex generators and in the outermost drift of the venturi inlets.
Beware of T-Rex
Re: Red Bull RB19
Vanja #66 wrote:
03 May 2023, 14:19
03 May 2023, 14:07
They ran it in Bahrain
Could you share a photo-proof please? :mrgreen:
Seems there was some misunderstanding as to what the "stacked" arrangement of the RB beam-wing is. They've had multiple dual element designs that could be considered to be stacked.. The one they ran in Bahrain was the more conventional dual-element design that they used at high downforce tracks in the 2nd half of '22, so I think it's safe to say I misinterpreted which BW was being discussed.
Re: Red Bull RB19
04 May 2023, 15:10
Vanja #66 wrote:
03 May 2023, 14:19
03 May 2023, 14:07
The one the RB18 launched with, one element right next to the diffuser and the upper one sitting almost horizontally seems to have fallen out of fashion for them.
Now RB either stacks them conventionally, one on top of the other or runs single element.
Re: Red Bull RB19
Miami rear wing
Beware of T-Rex
Re: Red Bull RB19
04 May 2023, 16:35
Miami rear wing
https://i.postimg.cc/mkRZvrLb/image.png
I'm expecting Bahrain RW with single element BW..
Re: Red Bull RB19
03 May 2023, 21:18
vorticism wrote:
03 May 2023, 20:43
03 May 2023, 14:07
I mean the stacked independent single element wings, not the familiar unified two element wings.
Many incl. James Allison are saying things like "they have a more powerful DRS." Saying it's the DRS mech alone is probably inaccurate. Note many of RB19's features: no halo wings, simple side mirrors, thinnest suspension members, sidepod design, smallest roll hoop intake this side of Ferrari powered cars.
I understand this point, but the low drag of the rest of the car is present regardless of whether the wing is open or not.
The increase in speed that you get from opening the rear wing, should be solely the result of the drag reduction of the wing itself (assuming it's not the trigger for stall elsewhere when it's open)
That's grossly inaccurate. :idea:
There is a field of flows around the entire car and the different streams interact in three dimensions. Think of a 3D lattice, or mesh. There is a "ripple effect" of changing the pressure in a given area on other areas.
Opening the DRS means more air static pressure behind not just the wing but pretty much the entire rear of the car.
Re: Red Bull RB19
PlatinumZealot wrote:
04 May 2023, 20:21
03 May 2023, 21:18
vorticism wrote:
03 May 2023, 20:43
Not sure if you missed this:
Beware of T-Rex
Andi76
Andi76
476
Re: Red Bull RB19
03 May 2023, 21:18
vorticism wrote:
03 May 2023, 20:43
03 May 2023, 14:07
I think they are "doing something". The extremely high top speed and especially the acceleration can't just come from that. If it were based on pure drag reduction, then everyone else would be doing everything wrong. Their flap is already completely different from that of the other teams. Here is a comparison with Ferrari.
Re: Red Bull RB19
Andi76 wrote:
04 May 2023, 21:38
03 May 2023, 21:18
vorticism wrote:
03 May 2023, 20:43
https://postimages.org/
Maybe it's as simple as the flap stalling the main plane very aggressively. When their DRS flap is open, it almost looks like it could be generating lift/downwash. Red Bull have been running heavily cambered rear wing main planes. More than any other team both last year and this year. The difference in the mainplane is visible in this picture.
Beware of T-Rex
Andi76
Andi76
476
Re: Red Bull RB19
04 May 2023, 21:41
Andi76 wrote:
04 May 2023, 21:38
03 May 2023, 21:18
That was exactly my thought.
vorticism
vorticism
449
Re: Red Bull RB19
Pretty sure they all turn up at the edges when in DRS flap open mode, due to the curving RW shapes imposed by the rules. You can see both the Ferrari and RB exhibit this in the comparison photos above. Look how the camber changes at the edges. ~45* at the S, ~23* at the W in this image:
scuderiabrandon
111
Re: Red Bull RB19
vorticism
vorticism
449
Re: Red Bull RB19
+1 scuderiabrandon. Single louver exit again. I suppose they could keep making the intake wider and more letterbox shaped. Fabrega:
BlueCheetah66
BlueCheetah66
Re: Red Bull RB19
vorticism wrote:
04 May 2023, 23:14
https://pbs.twimg.com/media/FvT_fxeWIAA ... ame=medium
Would love to have a new shot of the underneath of their floor. Really want to see how it compares to the RB18
Re: Red Bull RB19
04 May 2023, 20:42
04 May 2023, 20:21
03 May 2023, 21:18
Does not matter. Trigger or no trigger. Stall or no stall. Not having the blockage if the rear will will also reduce the drag of the surrounding areas behind it.
A good example is the McLaren "speed tail"
Talking about the RedBull DRS trick, James Allison interestingly said that the RB19 runs a lower ride height above a certain speed, that would cause problems if tried by another car...
It could be that the RB19 DRS has other effects than just reducing drag or stalling something.
