Re: no obvious s-duct exit yet. I am still hoping for low dual engine intakes. That said this emergence of two new inlets behind the halo bases could be alternative placement for such a split intake. Seems like an odd spot for a cooling intake so yeah it might also be another s-duct inlet candidate. That seems like an appealing spot for one.
Re: louver exit speculation in previous posts. The louvers must release only heat exchanger outflow per the regs. So if you're going to get clever with the louvers you have to also be clever with the HXs, which also have some regulations defining in them. I leave the rest to you.
Fabrega
↑ This is a major change. The radiator cores are constructed differently, they're closer to horizontal and mounted above some sort of tall structure which might be the floor tunnel or something else, and an air-air intercooler isn't visible. That structure appears to have an insulating foil on it; something you might want on an engine intake plenum running beneath a radiator.
organic wrote: ↑21 Feb 2024, 13:18
Here's a front angle without sidepod panel on
Notice the vertical slot doesn't immediately connect to the main radiator inlet... And there's no identified s-duct outlets yet...
+1s to all the image posters, very informative as always.
