2021 Pre-season testing. Bahrain 12-14 March
JordanMugen
86
Re: 2021 Pre-season testing. Bahrain 12-14 March
Juzh wrote:
20 Mar 2021, 20:08
another FOM prediction, this time from weekend debrief:
Circular dots are predicted positions and horizontal lines are margin of error for best case scenario and worst case scenario.
https://i.imgur.com/taJfVU9.jpg
Adding error bars is certainly an improvement in statistical robustness - well done FOM! =D>
Given the 95% confidence intervals, it suggests a less than 5% chance of a Mercedes-Benz pole position. :o :lol:
ferkan
ferkan
31
From Albano (FP, very detailed and on point analysis)
https://www.formulapassion.it/manifesto ... 56268.html
ferkan wrote:
21 Mar 2021, 21:22
https://www.formulapassion.it/wp-conten ... ria_FP.jpg
It appears that either Honda and Ferrari have overtaken Mercedes in the PU stakes, or Mercedes were sandbagging. Mercedes lost loads of time on straights.
ferkan
ferkan
31
Merc has the best one for sure. Customer teams data shows it, although difference seems small enough.
Ferrari gained north of 40HP, according to F1AT, which would put it at a level of Merc last year (which was also aim for Honda). I think Renault will be slowest this year, as Ferrari engined cars all had biggest RW as well and were ahead.
Jambier
So Ferrari and Honda gained 40hp
Mercedes 25?
Renault is doing only thing for 2022 so a +10-15hp max, they will struggle this year
JPBD1990
JPBD1990
49
ferkan wrote:
21 Mar 2021, 21:22
This just looks a lot like Ferrari used a higher engine mode than Mercedes. Which is to no ones surprise.
They seem to have lower apex speeds everywhere, so I don’t expect to see them fighting at the front this season. Maybe best of the rest against McLaren? I for one am up for that - clash of the classic titans, and let Mercedes and redbull do their own thing out front.
JPBD1990
JPBD1990
49
ferkan wrote:
21 Mar 2021, 21:22
Do you know if this poster has similar graphs for Ferrari vs Alfa, redbull vs AT, merc vs Williams, for example? It’s obviously hard to discern between engine power and aero differences, but would be interesting to see straight line speeds of the same engines in different cars.
Oehrly
JPBD1990 wrote:
22 Mar 2021, 06:07
ferkan wrote:
21 Mar 2021, 21:22
For Redbull vs AlphaTauri I have made a graph which I posted in the Redbull team thread here:
viewtopic.php?p=958683#p958683
Concerning mercedes in the above graph. They're effectively losing time everywhere, on straights and in corners. Comparing cornering speeds is a bit difficult in these graphs because the lines are so close together there. I'm pretty sure they were holding back to some extend at least.
JPBD1990
JPBD1990
49
Oehrly wrote:
22 Mar 2021, 09:59
JPBD1990 wrote:
22 Mar 2021, 06:07
ferkan wrote:
21 Mar 2021, 21:22
Incredible! Thank you
Not sure if this has been posted yet...
Quite the Variety...
henry
324
ferkan wrote:
21 Mar 2021, 21:22
FWIW I always compare the speeds at the start and finish of the lap for each trace. It tends to reveal something about resource use across the lap particularly ERS and tyres.
For Verstappen the speeds are almost identical suggesting the same ERS deployment at the beginning and end of the lap and tyres in similar condition.
For Hamilton the start speed is lower, 2 or 3 kph at the start than the beginning suggesting he didn’t push through turn 14 at the beginning of the lap and had plenty of ERS left at the end. Despite the slow start to the lap he was as quick as Verstappen at the end of the start finish straight.
For Sainz the start speed is much higher than the end, 5 or 6 kph , it looks as though he ran out of ERS and maybe some tyre with a low apex speed at turn 14.
In past traces I’ve looked at on Q laps the finish speed is usually a little lower than the start. I’d conclude that Verstappen was cruising, Hamilton wasn’t pushing, at least at the start of the lap, and Sainz was nearer to using up his tyres and ERS than the other 2.
HungarianRacer
HungarianRacer
henry wrote:
22 Mar 2021, 12:11
ferkan wrote:
21 Mar 2021, 21:22
Acceleration above 290 km/h will always tell more about aero setup or inherit drag levels of certian cars rather than power output, because at those speeds the resistive forces are such that even a relatively big power difference will make little difference, plus it's safe to assume that everyone would get similar levels of de-rating, regardless of engine mode (no point in wasting energy against that kind of resistance just before a braking zone).
henry
324
HungarianRacer wrote:
22 Mar 2021, 12:59
henry wrote:
22 Mar 2021, 12:11
ferkan wrote:
21 Mar 2021, 21:22
I meant ERS at the end of the lap rather than end of the straight. I agree that it is unlikely that they will be using the MGU-K at the end of the straight.
But yes, we might draw the conclusion that the Mercedes had lower drag, and lower downforce?, than the Red Bull, most noticeable through 5,6,7.
Nonetheless, had Hamilton attacked the beginning of the lap his speed at the end of the start finish straight would have been several kph higher.
ferkan wrote:
21 Mar 2021, 21:34
Renault speed traps were nothing special during winter testing in 2019 and 2020, but they were very good during the season in qualy and race.
Hoffman900
Hoffman900
212
Love all the speculative dyno racing going on here. :lol:
