McLaren MCL60
Re: McLaren MCL60
Marco Alves wrote:
11 Jul 2023, 14:51
Has anyone found a good photo of the changes to the rear brake ducts and rear suspensions?
No New Suspension... Only the Cover of Suspension Arm...
Rear Brake...
Farnborough
Farnborough
124
Re: McLaren MCL60
I know it's a variation in absoltue camera angle in the two above images.....but the top rearmost link appears to be shifted in the two....and not really accounted for by camera angle change.
I think there's enough consistency in the two pictures to judge that rear top link has repositioned inner pickup location.
Notably, the MCL60 is the only other chassis that shares pull front and push rear spring operation, same as RB.
f1rules
f1rules
623
Re: McLaren MCL60
from the latest unboxed video you can see they are exploiting the floor iceskates more, at the start when the car leaves the pits, you can see the refleksion in the pit floor and when it leaves the garage
Ive highligthed the best i could and you can clearly see the reflection in the floor, with the big skirt and the floor edge channel, keep in mind its upside down
_cerber1
273
Re: McLaren MCL60
CjC
CjC
Re: McLaren MCL60
What is that half way down Mclarens waterslide?
At first I thought it was a duct so I zoomed in. It’s not a duct but it looks like the slide changes in pitch? To alter the air speed?
Just a fan's point of view
Balalu
Balalu
Re: McLaren MCL60
CjC wrote:
19 Jul 2023, 21:16
Looks like shade of the inner side lip.
Edit: zooming in, it actually looks like the carbon weave.
"I showed him [with my hands] and said: I have bigger balls!” - Mika Hakkinen
scuderiabrandon
111
Re: McLaren MCL60
CjC wrote:
19 Jul 2023, 21:16
Looks like a joint between 2 seperately molded pieces and the weave pattern is not aligned.
LionsHeart
LionsHeart
Re: McLaren MCL60
New rear wing from McLaren: If I saw it clearly, then an updated rear wing was brought to McLaren! Hurrah, finally! Take a close look at the articulation of the main flap and the top flap. The slit between them continues further down, I have not seen this before in Monaco:
LionsHeart
LionsHeart
Re: McLaren MCL60
Aaahh! No, my bad. This is same rear wing from Monaco:
https://ibb.co/mCbCCrY
Macafangrskg
Macafangrskg
Re: McLaren MCL60
We probably found a lot of downforce from the underbody because for the first time we look like we are not the champions in barn door competition
Re: McLaren MCL60
https://www.youtube.com/shorts/3_Yev3Lqd3I
Old, but Ted also says new Rear Suspension in Austria...
onewingedangel
onewingedangel
Re: McLaren MCL60
Marc.W
26
Re: McLaren MCL60
onewingedangel wrote:
20 Jul 2023, 16:38
Floor stay no longer goes through the slide up to the engine cover, is the double T-Tray new?
Xero
32
Re: McLaren MCL60
Marc.W wrote:
20 Jul 2023, 16:39
20 Jul 2023, 16:38
Same T-Tray as Silverstone looking back at pictures.
mwillems
46
Re: McLaren MCL60
mclaren111 wrote:
20 Jul 2023, 16:26
The suspension changes in Austria appeared to be some slight changes to create the appropriate gap for the airflow to meet the rear, nothing revolutionary.
-Bandit
