2024 Scuderia Ferrari F1 Team
Fakepivot wrote:
05 Jul 2024, 12:35
How is the weather looking?
Cold & wet
Mansell89
Mansell89
How do people expect to fair here this weekend?
It’s more sweeping fast direction change here than long corners isnt it, and so I wonder if that might allow Ferrari to get around some of their issues?
ScuderiaLeo
I don't know if that source is reputable on its own, but two of the other quotes in the article are from Formu1a.uno. Assuming this article is a rewrite of other Formu1a.uno articles, it might be the writer mistranslated what they said about the two cars doing different tests. This was also mistranslated on Twitter, but a Formu1a.uno writer disputed it:
https://x.com/_Paolo_27/status/18086104 ... XRq2w&s=19
"Just to clarify, @GiulyDuchessa talked not about a comparison about cars (floor or whatever), the SF-24 will be fitted with all the upgrade and no other updates are expected. The comparison we talked is about the preparation of Qualyfing. Leclerc and Sainz will try diffrent outlaps, diffrent approach on how to do the Qualy lap to try to improve in that area. About bouncing just work on setup (aero and mechanical side, as correctly reported)"
This was two days ago. Of course, it's also possible something changed since then.
Sphere3758
Sphere3758
05 Jul 2024, 12:36
Fakepivot wrote:
05 Jul 2024, 12:35
Cold & wet
According to twitter, the sun is out now and warming up just before fp1
dia6olo
dia6olo
The Sainz time on the hard is actually very good...
Xyz22
Xyz22
123
Seems they are doing a lot of tests. Sainz laptime on hard tyres was done on a very aggressive engine map according to Marc Genè.
dia6olo wrote:
05 Jul 2024, 14:31
Different engine map.
dani5549
dani5549
Not a bad race sim in my opinion for Leclerc but depends on engine mode i guess
Sphere3758
Sphere3758
Intriguing stuff. Bozzi was mentioning Max's times to Leclerc, so they probably thought they were on a comparable run plan. Charles was a bit faster which made it interesting :)
ScuderiaLeo
Do we know if Sainz is on the old spec? Sky Italy and some other on-site reporters are saying he is, but other ones like Canal haven't mentioned it, so I can't tell if it's misinformation spreading or actually true.
MV8
MV8
ScuderiaLeo wrote:
05 Jul 2024, 14:34
He did not bounce so it's probably he is in pre-barcelona spec.
Just posting
CaribouBread
CaribouBread
101
ScuderiaLeo wrote:
05 Jul 2024, 14:34
From an eyeball test, Charles was bouncing - Carlos was not. I'd say Carlos was running a pre-upgrade floor/sidepod.
Xyz22
Xyz22
123
It's confirmed that Sainz was running the old spec.
ScuderiaLeo
Thanks all @ the confirmation, was watching from my phone this time so couldn't see the onboards to compare the bouncing.
Lots to chew on for Ferrari...
codetower
How were the long run times between the two specs? Because judging by single lap time, the new spec was only half a tenth quicker on a softer compound. Not good.
Sphere3758
Sphere3758
codetower wrote:
05 Jul 2024, 14:57
That was not really the case. Carlos did not improve his time set on hards on the medium.
Charles looked faster in the long runs to Carlos too and was matching/slightly faster than Max (who was being provided as a reference to Charles).
So it is not all doom and gloom. I don’t know about the bouncing though, did not follow the onboard too much
