2024 Scuderia Ferrari F1 Team
Sphere3758
Sphere3758
codetower wrote:
05 Jul 2024, 14:57
How were the long run times between the two specs? Because judging by single lap time, the new spec was only half a tenth quicker on a softer compound. Not good.
That was not really the case. Carlos did not improve his time set on hards on the medium.
Charles looked faster in the long runs to Carlos too and was matching/slightly faster than Max (who was being provided as a reference to Charles).
So it is not all doom and gloom. I don’t know about the bouncing though, did not follow the onboard too much
Autobahn303
Autobahn303
Charles pace on the long run looked encouraging.
SoulPancake13
SoulPancake13
Charles long run pace looked super strong. When they get the right setup with the car it seems the race pace is strong but the qualy balance got even worse with the latest upgrade
Xyz22
Xyz22
118
Race pace being good is not enough, unfortunately. Starting behind in P5 and P6 you can't do much if you are a few tenths faster.
KimiRai
KimiRai
249
Ferrari compared the Imola package with the Spain one. The best SF-24 would be the fusion of the 2 packages: the FP1s have in fact confirmed that the Imola Spec is on average better at fast speeds while the Spain Spec is better at slow speeds.
CaribouBread
CaribouBread
101
KimiRai wrote:
05 Jul 2024, 15:32
My guess is that the Spain spec probably performed as good as the Imola floor in the high speed in the simulators, which explains the hurry in bringing the upgrade forward. Honestly if they figure it out, this bodes well.
SoulPancake13
SoulPancake13
CaribouBread wrote:
05 Jul 2024, 15:39
KimiRai wrote:
05 Jul 2024, 15:32
On their fastest laps, Sainz was 10kph up through Chapel on minimum speed... the bouncing is a huge issue and embarrassing in 2024.
Sphere3758
Sphere3758
SoulPancake13 wrote:
05 Jul 2024, 15:44
CaribouBread wrote:
05 Jul 2024, 15:39
KimiRai wrote:
05 Jul 2024, 15:32
But wasn't Carlos on a more aggressive engine mode on his fastest lap ? I am not sure if those numbers are comparable
yooogurt
36
Sphere3758 wrote:
05 Jul 2024, 15:48
From the formula uno above:
Sainz, however, was unable to improve on his C2 result despite three fast laps, a sign that the lap in C1 a few minutes earlier was probably done with a more aggressive engine mode.
FORZA FERRARI!
CaribouBread
CaribouBread
101
05 Jul 2024, 15:44
Agreed. It is an embarrassing fumble at this point of reg development. But one has to be hopeful, they've figured it out before, hopefully they can recover that characteristic again.
Fede90
Fede90
Is it clear if the performance degradation, in high speed turns, is due to the floor?
SoulPancake13
SoulPancake13
Even in FP2 they will run different spec cars...
dialtone
dialtone
118
So LEC couldn’t use 8th gear through copse? I think they are both reverting if that’s the case.
SoulPancake13
SoulPancake13
dialtone wrote:
05 Jul 2024, 16:57
Not what Duchessa is saying as of now, Charles is happy w the new floor apparently.
CouncilorIrissa
CouncilorIrissa
CaribouBread wrote:
05 Jul 2024, 15:53
05 Jul 2024, 15:44
They didn't figure out how to run low tunnel roof and not porpoise, they simply raised the tunnels with the Barcelona 2023 upgrade and bouncing was gone (while also losing performance on paper).
Now that they lowered them again with the Barcelona upgrade, bouncing is also back.
I think Vanya will correct me if I'm wrong, but from what I gathered by reading his posts, lowering the tunnel roof is one of the easiest ways of gaining DF under this ruleset, while also being of the riskiest as you need to be very careful not to introduce porpoising.
https://www.f1technical.net/forum/viewt ... 7#p1185797
