2 rotations; down,up, down,up => suck, squeeze, bang, blowdans79 wrote:+ 1 on this, a cylinder only fires once every 4 rotations of the crank.Dragonfly wrote:You can't have 6 injections per rotation. This is a 4 stroke engine.
thomin wrote:Yeah, you're right, silly me...that was actually why I went for 36 rotations per 0.2 seconds, so that I can divide it by 4...but I somehow got lost in the numbers...Dragonfly wrote:You can't have 6 injections per rotation. This is a 4 stroke engine.![]()
That would go on to increase the impact of an offset though...Instead of 36 injection events you'd have 9...or taking half rotations into account, instead of 72, you'd have 18.
That would translate to 105.555 kg/h in a cycle where you measure 19 instead of 18 injection events.
So on the extreme end, a team would have to reduce its internal fuel flow to 94.7368 kg/h in order to be on the safe side, which would be in line with what we heard form the various teams.
Just to be clear – I didn't mean to seem negative on this. I think you've hit upon a really great explanation for why a fuel flow meter might see very different values from what you might see at the injector level.thomin wrote:I think I got it still wrong as beelsebob had it right, that we have to disentangle all 6 cylinders. Depending on the offset, that could reduce the numbers again. I might take a moment later on and do some real math instead of embarrassing myself further with these off-the-cuff calculations. Also, I think some graphs might be helpful. I'll see what I can do.
But I still think that this phenomenon could be at the root of all this. In-sync readings may very well differ quite a bit from random, out-of-sync readings.
afaiu the sensor samples at 1KHz that is then filtered (averaged if you will) to provide measurements at 5Hzbeelsebob wrote:Just to be clear – I didn't mean to seem negative on this. I think you've hit upon a really great explanation for why a fuel flow meter might see very different values from what you might see at the injector level.thomin wrote:I think I got it still wrong as beelsebob had it right, that we have to disentangle all 6 cylinders. Depending on the offset, that could reduce the numbers again. I might take a moment later on and do some real math instead of embarrassing myself further with these off-the-cuff calculations. Also, I think some graphs might be helpful. I'll see what I can do.
This actually makes it rather important that the FIA *must* specify a measuring time, because without it, you could end up with extremely high readings. If for example you sample for half the length of time that the injector opens, every so often, you'll get one extremely high reading, due to the injector being open, and then a bunch of near 0 readings while none is open.
So that does support a theory that Technical Directives hold no weight?“My own view is, and it’s purely a personal view, that it would open the floodgates to all sorts of things if this appeal were to be successful because, yes, the ICA is the final arbiter, opinions given by the FIA outside of the Technical Regulations are meant for guidance and they are guidance, it doesn’t constitute part of the Technical Regulations as such, but I think some things should be reasonably straightforward.
Well, no. Red Bull are saying they did comply with the strict wording of Article 5.1.4 - which has been their position from the start.The fact that it made the car faster or slower is irrelevant.“If Red Bull chose to ignore the guideline from the FIA then they will have only done that to make their car go quicker - there’s no reason why they would have done anything other than that.”
This isn't the whole point though. Red bull aren't allowed to decide that they know best and can ignore FIA. I'll be amazed if they don't get some harsh criticism for their actions.WilliamsF1 wrote:The discussion in the appeal court is going to be if the sensor was working or not and who is in a better position/informed to make that decision. As redbull would have had both sensor and injector data I think it was is fair for them to take the call that the CIA sensor is not working.
I am sure fia has a copy of the fuel maps for the race and could cross check the code for any foul play.
bonjon1979 wrote: This isn't the whole point though. Red bull aren't allowed to decide that they know best and can ignore FIA. I'll be amazed if they don't get some harsh criticism for their actions.
