Williams FW35 Renault
Re: Williams FW35 Renault
http://www.f1technical.net/forum/viewto ... &start=600
Actually they have that one since last year.
Seamus
Seamus
True. They used it at Spa & Monza.
Italy 2013 - Thursday (06.09.2013)
trinidefender
trinidefender
317
Very interesting . Williams have switched from flowing the wheel nut the blowing through the wheel rim to try and control airflow around the front tyre. Lets see if this helps
Singapore 2013 - Tuesday (17.09.2013)
via Dickie Stanford
What is with the neon garb?
So they are more visible and don't get run over by forklifts or trucks during unpacking & installing garages and packing up after the race.
raymondu999
Yes. Do remember the race is done at night.
失败者找理由,成功者找方法
Francesc
Francesc
49
raymondu999 wrote:Yes. Do remember the race is done at night.
It's not for that. They do wear them in every race.
Juzh
161
What are those for?
notApineapple
notApineapple
Juzh wrote:What are those for?
http://shrani.si/f/3l/112/14MlpkBW/9h4moj4.jpg
Looks like a lambda sensor (for measuring air fuel ratio) and thermocouple (for measuring temperature).
rssh
They are most probably temperature sensor (definately not EGR :lol: ); but don't know why there are 2 of them.
trinidefender
trinidefender
317
Temp sensor and probably O2 sensor which can help determine Air/fuel ratio
drunkmunky
drunkmunky
one is an egt (exhaust gas temperature) sensor.
the next is a wideband o2 to ensure that the a/f ratio of the engine is correlating with optimal running
I think it is useful for pitstops, make it easier to see where the wheel has to go on.
