2024 Austrian Grand Prix - Spielberg, June 28 - 30
TFSA
Re: 2024 Austrian Grand Prix - Spielberg, June 28 - 30
So just out of interest, i decided to get the telemetry from Max on Turn 3 on Lap 55, as well as the lap 64 crash and recorded it on his onboard at 1/8x speed. Lap 55, his onboard was unfortunately facing backwards, but i think it's still telling. The videos are on IMGUR, so sadly can't embed them here.
Lap 55 (VIDEO LINK): Max is completely on the outside of the track, and then suddenly sweeps across to the inside line while braking, passing pretty much 70-80% of the track. That's clearly moving under braking to me, and should have been acted upon by the stewards
Lap 64 (VIDEO LINK): The crash. Max is more or less in the middle of the track (about 45% from the left), makes a small correction to the left before the braking zone, and then brakes with the steering wheel straigth, going from the 45% mark to about the 20% mark to the left, meaning he moved about 25% across the track.
I'm still gonna argue that Lap 64 is a racing incident. It was a bit naugthy, but he only moves about 25% across the track, it was very gradual, he corrected before he braked (steering wheel straigth while he braked), and it was absolutely avoidable by Lando by taking a bit of kerb. But it's expected that people are gonna have differing opinions on that one.
FW17 wrote:
03 Jul 2024, 08:01
Separate to this debate, What happed to the DRS in Austria?
They had 3 at the track, one followed by the next but in none of them the cars were able to do regular over speed on the DRS zone and had to depend on lunges. I was surprised that the cars could not even get part of it side by side of the car in front before the braking zone that would have led to normal overtaking
It's a combination of the corners being a bit too narrow for the size of the current cars, and the straigths which are DRS zones - even if they are in succession to each other - being a bit too short. It's only really the T1-T3 straigths which is somewhat long, but it goes uphill.
venkyhere
FW17 wrote:
03 Jul 2024, 08:01
T3-T4 straight comes after mega braking for T3 (the car is still going uphill during the turn), so we are talking about 2 digit exit speed from the corner. WIthout serious pace difference, DRS delta wont yield much, since some distance will be wasted for the cars to build speed that is fast enough for rear wing drag to matter.
T1-T3 is steep uphill, so the AoA of the rear wing is lowered naturally, that means even the car in front, has lesser drag than it would have had otherwise, in a 'plain' straight.
T10-T1
I can't think of a reason.
Air density as such being lower, perhaps, considering the elevation of the RedbullRing location ?
venkyhere wrote:
03 Jul 2024, 10:13
Er, no.
venkyhere wrote:
03 Jul 2024, 10:13
T10-T1
There are a couple of reasons that always apply:
- the following car is always getting hurt on exit before DRS zone unless the driver is particularly focused on good exit and selected the appropriate deployment mode, this point is particularly important in fast and delicate corners such as T10
- inappropriate harvesting mode will introduce clipping too soon while DRS is still on, this was present quite often with Norris and seemed to sometimes coincide with his overtaking attempts
- overall Top Speed capabilities, which were again not so good for McLaren in Q this weekend
Going up or downhill has no effect on aero with regards to ground's coordinate system, if there's no wind it does not matter.
SiLo
139
The best thing the FIA could do is get rid of this stupid "ahead at the apex" nonsense. It's really warped overtaking because it doesn't seem to even consider actually being able to make the corner properly.
Felipe Baby!
90feet
90feet
Nevermind.
101FlyingDutchman
101FlyingDutchman
SiLo wrote:
03 Jul 2024, 12:14
Totally agree with that. It’s a big reason why the divebombs have become so typical. It also then promotes running anyone on the outside out of road.
Problem is, there is no way to tie down a black and white version. Every single case is pretty much unique.
I simply utterly abhor the “make no attempt to take a racing line that allows side by side racing, back out or we shall crash attitude”
SiLo
139
101FlyingDutchman wrote:
03 Jul 2024, 14:31
SiLo wrote:
03 Jul 2024, 12:14
1. Always leave a cars width (attacking and defending cars).
2. Both cars must be able to make the corner without requiring avoiding action.
3. No moving in the braking zone, pick a line and stick to it.
4. Defending car cannot make multiple defensive moves in a single overtake attempt.
Felipe Baby!
venkyhere
venkyhere wrote:
02 Jul 2024, 18:01
My Q is, what do the rules say, in terms of what happened in lap 63. Should Max have given the position back ? (because had he done so, what happened in lap 64 would've been entirely different). I saw posts which said "Lando gave back position after driving around outside the corner, but Max did not". Hence want to know whether the rules are different in each case since in one case (lap 58/59) it was the attacker who went outside and came out in the lead, in the other case (lap 63) it's the defender who went outside and came out in the lead.
Ans 1 :
cheeRS wrote:
02 Jul 2024, 19:24
That's what it is. Attacker vs defender will always lead to different decisions from the stewards (can't remember if the rules explicitly say this but it's the de facto standard). See Canada 2014 (Ham attacking Rosb) for an extreme example.
Ans 2 :
hollus wrote:
02 Jul 2024, 22:01
In Lap 63, T3, Norris dives inside, makes the corner but still puts his outside wheels in the white line, meaning that literally there is no space for Verstappen not to leave the track while not colliding. The only reason he is briefly ahead for a tenth of a second in the apex is by denying any track to his rival. What others call attacking vs defending, I guess.
So still no oranges to oranges comparison.
Ans 3 :
Tvetovnato wrote:
02 Jul 2024, 23:37
I think it’s clear that Verstappen is right to stay ahead by driving off track. The divebomb move creates a problem here that seems to be hard even for drivers to understand fully. Yes, you are alongside at the apex, and when you are, you are normally allowed to dictate the corner. But the problem is how you got there in the first place and where you ended up. The divebomber is only alongside at the apex due to an abnormal entry speed which most often means he overshoots the apex and takes the defending driver with him/makes him take evasive action. The defending driver HAS the right to be able to stay on track all through the corner in this situation, since he is clearly ahead at the braking when the divebomber starts his move. Hence Verstappen did the right thing, just as Hamilton in AD21 and none of them were penalized.
All three above answers seem to indicate that if the defending car is forced outside the track by the inside 'attacker' car. and the defending car retains the lead when rejoining after the corner, the defedcer needn't concede position to the attacker, since the onus falls on the attacker, because he was the one who wanted to change the status quo.
However, Jolyon Palmer thinks otherwise, and doesn't differentiate between the two situations :
skip to 3:24 and watch until 8:56
https://www.youtube.com/watch?v=ER4_6N86M_U
SiLo
139
venkyhere wrote:
03 Jul 2024, 16:38
That's some very good analysis from Palmer there.
Felipe Baby!
hollus
Just for the record, Joylon does differentiate between the two situations.
This below was your original question, and the one we tried to answer.
What do FIA rules say, does driver B have to give the position back or incur a penalty ?
Does the answer to above Q depend upon who was the 'overtaker' and who was the 'defender' ?
So, since you chose to single out those answers, I just want to clarify:
The answers were to "does the answer to above Q depend..." (https://www.f1technical.net/forum/viewt ... 3#p1228063)
And that is still not oranges to oranges.
Then Joylon is anlyzing something different.
Nice piece by Palmer, though. Very clearly argued.
TANSTAAFL
Farnborough
Farnborough
124
Seemed a very thorough overview by JP, measured, factual and clear.
Ultimately, with automation of gears changing, arrangement of energy deployment etc, etc coming out of corner one, then not much advantage is available until the drag from slipstream and DRS effect finally accumulate at just about the braking point to the corner !
This all naturally compresses any overspeed straight into that contentious area of behaviour, aided by track topography in rising that allows every driver to "bury" the kinetic output into that braking zone.
There's a very, very compressed action zone to sort it all out. No wonder that this corner often brings this type of outcome, likely at every future GP there too.
With Spa, China, Baku etc, the combined overspeed always has time to develop into reasonable space as it accumulates much before the brake point, generally less combat is the result.
Shorter tracks, then the DRS never reaches its effectiveness before braking is imperative.
TFSA
Unfortunately, Palmer actually makes several (factual) mistakes in that analysis.
Talking the two overtaking attempts where Verstappen regained the lead (Lap 59 and Lap 63).
Palmer chastices Verstappen for "moving a bit" under braking in those situations, which Verstappen did do, and say he should perhaps have gotten a warning or a penalty. However, he forgets that part of the original moving under braking rule had the condition, that it's only illegal if it forces another driver to take evasive action. Norris didn't take evasive action on any of those laps, and as such, by the original rule, it's not an illegal move on those two laps. It's good defense.
Here's the rule as it was introduced in 2016, Since then, the rule has just been baked in under "dangerous" or "erratic" driving:
With this in mind, and with the exception of any move permitted by Article 27.6, any change of direction under braking which results in another driver having to take evasive action will be considered abnormal and hence potentially dangerous to other drivers. Any such move will be reported to the stewards.
As per my previous post though, and Palmer also touches on this, it was clearly a very illegal move on Lap 55 where Verstappen sweeps across the track. But lap 59 and 63? Completely legitimate defense.
The second part i disagree with, although i won't necessarily call it a factual mistake by Palmer, is the Lap 63 overtake being legitimate and Verstappen being able to stop the car and remain on track. While Verstappen did go off the brake middle of the corner and did a very slight bit of throttle, i absolutely do not see him being able to stop the car and making the corner with Lando diving there, looking at the onboards. While Lando did remain on the track himself this time, this is clearly a too deep and too late divebomb, and he forces Verstappen to make a correction on the steering wheel. That correction is what caused Verstappen to go off, even had he remained on the brake - and since it was forced by Lando, this cannot be reasonably judged as anything but forcing another driver off the track.
SlowMotion Video.
Verstappen have been critisized (and occasionally punished) for similar moves himself, and i definitely do not see this as a great dive. It was a little bit too deep and too late, even if Lando remained on track. On a discussion with Dialtone on race day in the Discord, we both agreed that it's time that the FIA start policing those type of divebombs. They were both racing dirty.
(on a sidenote, Verstappen saying "That's not how you overtake" is massively ironic, since he does it himself all the time)
dialtone
dialtone
123
TFSA wrote:Unfortunately, Palmer actually makes several (factual) mistakes in that analysis.
SlowMotion Video.
Lando blocks his front tyres on first attempt and goes from being on the inside to being on the outside of the corner during braking. What does evasive action look like for you? Car only goes left or right, can’t jump or fly.
On the 2nd attempt Lando makes the apex and turns properly, hard to call that a dive bomb, he’s also ahead at the apex and thus can practically make Max’s car explode and not be penalized. 100% Max should have been penalized for this one as well as he definitely gained an advantage by being off track.
Again, rules that take so long to be interpreted and eventually aren’t applied are bad rules, but JP’s analysis is very factual.
dialtone wrote:
03 Jul 2024, 22:29
He's not ahead at the apex he only appears ahead near the exit, if Max had turned in he would've gotten topedoed right in the sidepod.
And Lando clearly doesn't leave a cars width on the exit.
