The Higher DF wing would benefit more the race pace, the lower wing the Qualifying. It's not just deg, sliding increases the temp of the tyres which does increase deg but also lowers grip and therefore cornering pace and exit traction and this is something the Mclaren would prefer to avoid if the lower DF wing isn't sufficient.MCLvamos wrote: ↑01 Sep 2023, 14:10With my limited expertise, I'd believe the higher DF wing is more quali focused whereas the lower DF wing is more a view to raceability in the Grand Prix itself. Yes, higher DF will look after the tyres better but I suspect the battery benefits plus the time gained especially with DRS off will outweigh that on an already low deg circuit in Monza.
Higher df at monza is better for the race. Not only for tyre protection but it actually also makes overtaking easier despite lower topspeed on paper because you can follow closer through the high speed (esp parabolica) and higher df wings still hit similar topspeeds with drs openMCLvamos wrote: ↑01 Sep 2023, 14:10With my limited expertise, I'd believe the higher DF wing is more quali focused whereas the lower DF wing is more a view to raceability in the Grand Prix itself. Yes, higher DF will look after the tyres better but I suspect the battery benefits plus the time gained especially with DRS off will outweigh that on an already low deg circuit in Monza.
Over a lap they look similar but I look forward to seeing the top speed data in a little bit.
Plus the tyre temps, something the Mclaren needs to control more than some others.organic wrote: ↑01 Sep 2023, 14:16Higher df at monza is better for the race. Not only for tyre protection but it actually also makes overtaking easier despite lower topspeed on paper because you can follow closer through the high speed (esp parabolica) and higher df wings still hit similar topspeeds with drs openMCLvamos wrote: ↑01 Sep 2023, 14:10With my limited expertise, I'd believe the higher DF wing is more quali focused whereas the lower DF wing is more a view to raceability in the Grand Prix itself. Yes, higher DF will look after the tyres better but I suspect the battery benefits plus the time gained especially with DRS off will outweigh that on an already low deg circuit in Monza.
If this is the case, perhaps they have put the higher DF wing on Norris' car in preparation for a possible engine penalty so setting up for the race?mwillems wrote: ↑01 Sep 2023, 14:18Plus the tyre temps, something the Mclaren needs to control more than some others.organic wrote: ↑01 Sep 2023, 14:16Higher df at monza is better for the race. Not only for tyre protection but it actually also makes overtaking easier despite lower topspeed on paper because you can follow closer through the high speed (esp parabolica) and higher df wings still hit similar topspeeds with drs openMCLvamos wrote: ↑01 Sep 2023, 14:10With my limited expertise, I'd believe the higher DF wing is more quali focused whereas the lower DF wing is more a view to raceability in the Grand Prix itself. Yes, higher DF will look after the tyres better but I suspect the battery benefits plus the time gained especially with DRS off will outweigh that on an already low deg circuit in Monza.
Having a lower DF wing can increase the temps in the racing tyre as the car slides and hinder cornering performance, including exit traction.
I don't think they'll need to take any engine penalties. The allocation is now 4 ice, 4mguk etc rather than 3 so most teams won't take engine penalties this season
I'm not sure how the two correlateMCLvamos wrote: ↑01 Sep 2023, 14:25If this is the case, perhaps they have put the higher DF wing on Norris' car in preparation for a possible engine penalty so setting up for the race?mwillems wrote: ↑01 Sep 2023, 14:18Plus the tyre temps, something the Mclaren needs to control more than some others.organic wrote: ↑01 Sep 2023, 14:16
