Renault R31
Re: Renault R31
Ok, but look at the gurneys placed on the diffuser; their presence would mean that the air flowing above the diffuser is quite powerful, wouldn't it ?
AbbaleRacing77
AbbaleRacing77
Re: Renault R31
Like i said its not a unobstructed free flowing stream of air (we know this). But the air is still being pushed through. The air has to go somewhere especially at 200mph. And if its not... Then i would think theres gonna be some major cooling issues. Like i said... If it didnt work, it would be pretty unintelligent to design sidepods that big... And dont even try to tell me that its because its to make room for the forward routed exhausts. Its a 4 or 5 inch pipe not a sewage drain.
Ringo... that huge opening in the front of the side pod + 200mph = your mass flow for ya
***Perfect example--- Ever look at a super trap exhaust or a muffler in general? Would you agree that its turbulent? Now what has a more powerful flow... a muffler setup or straight pipes? Your answer... theyre exactly the same.. yes the muffler has more resistance and turbulence (nobody denies this) but under pressure theyre gonna flow the same amount of air because the same amout of air is coming out of the motor and being forced out the end of the exhaust. Your turbulence theory is irrelevent when under alot of pressure.
Now add a nozzle to the end of that muffler for a higher velocity (Nozzle= r31 tiny sidepod exits)... this is what renault is doing in theory
Im getting tired... can someone that understands take the night shift to explain this once again to the next person that tells me its turbulent under the engine cover... Thanks
raymondu999
Re: Renault R31
Don't gurneys usually mean a lot of drag?
失败者找理由,成功者找方法
timbo
timbo
113
Re: Renault R31
ringo wrote:The top of the diffuser needs more than hot air, it needs mass flow.
Yeah, but on that particular car (and a few others) we see cooling outlets with much smaller area than inlets. That should bring energy back.
Twaddle
Twaddle
Re: Renault R31
You might want to re-word that slightly. It should increase the velocity out the back, but bring energy back it most certainly can't.
I'm wondering how much of the pressure loss associated with the increased velocity is offset by the heat picked up from the radiators and how much they're relying on the gurney to restore pressure above the diffuser.
timbo
timbo
113
Re: Renault R31
Well, maybe energy density is better?))
One thing is certain to me, radiator inlets are oversized compared to RedBull (same engine/KERS) – IMO that indicates they are playing tricks with the flow in and out of sidepods.
Re: Renault R31
Much bigger brake ducts + mecanic/aero (?) tests on the wheels
Callum
Re: Renault R31
Blackout wrote:Much bigger brake ducts + mecanic/aero (?) tests on the wheels
I believe they are tyre temp sensors. (most of the equipment is behind the tyre and out of view in this picture)
scarbs
scarbs
393
Re: Renault R31
They're wheel force sensors for building up their tyre simulation models...
see:
http://www.kistler.com/LI_en-ch/13_Prod ... -cars.html
Callum
Re: Renault R31
scarbs wrote:They're wheel force sensors to building up their tyre models...
see:
Boom, that's me proven wrong.
Are there tyre temp sensors that span half the tyre kindof like this guys glasses?
netoperek
netoperek
Re: Renault R31
Callum wrote: Are there tyre temp sensors that span half the tyre kindof like this guys glasses?
You can measure thermal radiation of the tire
scarbs
scarbs
393
Re: Renault R31
http://scarbsf1.wordpress.com/2010/12/0 ... abu-dhabi/
nacho
nacho
Re: Renault R31
Nice flew on the wing, could be more though.
tom12333
tom12333
Re: Renault R31
Tere are another temperature stickers near the rear crash structure.
Owen.C93
Owen.C93
177
Re: Renault R31
Can I just say the main part of the rear wing is rather large, I would have though you would want the lower part to be pretty flat to get the most of the ARW.
Here's the McLaren to compare, note the larger flap size.
