348 in fact at his fastest with no tow, at least the nearest car was 700m away, this is just over 6 seconds so juuuust outside a tow perhaps. Norris was 337 with no tow at all.LionsHeart wrote: ↑01 Sep 2023, 18:10I saw that Oscar is in the top 3 in terms of maximum speed. He scored 346 km/h.
The API can provide telemetry and 2 columns are Driver Ahead and Driver Distance ahead. Around just over 100m is a second. Typically a tow is 6 seconds or less.
I got you. And on the fastest lap? The difference between our drivers is minimal on soft tires.mwillems wrote: ↑01 Sep 2023, 19:09348 in fact at his fastest with no tow, at least the nearest car was 700m away, this is just over 6 seconds so juuuust outside a tow perhaps. Norris was 337 with no tow at all.LionsHeart wrote: ↑01 Sep 2023, 18:10I saw that Oscar is in the top 3 in terms of maximum speed. He scored 346 km/h.
On face value, it seems the low df doesn't work, but who knows, perhaps there was a fuel differential, difference in engine maps. Actually I'm not sure when he did this fastest speed, and at one point one driver was Meds and one Hards so.....
I can add that the highest speed for Lando without Tow occured on Lap 8 and for Oscar, Lap 14.LionsHeart wrote: ↑01 Sep 2023, 19:19I got you. And on the fastest lap? The difference between our drivers is minimal on soft tires.mwillems wrote: ↑01 Sep 2023, 19:09348 in fact at his fastest with no tow, at least the nearest car was 700m away, this is just over 6 seconds so juuuust outside a tow perhaps. Norris was 337 with no tow at all.LionsHeart wrote: ↑01 Sep 2023, 18:10I saw that Oscar is in the top 3 in terms of maximum speed. He scored 346 km/h.
Thank you so much!mwillems wrote: ↑01 Sep 2023, 19:22I can add that the highest speed for Lando without Tow occured on Lap 8 and for Oscar, Lap 18.LionsHeart wrote: ↑01 Sep 2023, 19:19I got you. And on the fastest lap? The difference between our drivers is minimal on soft tires.mwillems wrote: ↑01 Sep 2023, 19:09
I'm going to play with the API tonight and see if I can extrapolate compounds also and put it into a cube of data, which I will make available.
I'll take a look at the fastest lap.
