I think he's right. Imho it's actually pretty easy to compare, the fixed angle between the chamber and the rest of the exhaust does not change even if you view it from a different angle. The Helmholtz chamber clearly points downwards compared to the exhaust outlet from the Malaysia pic. Also the exhaust is brand new. You can see it from the color of the metal.Joie de vivre wrote:you're wrong
Probably the rear tires requires less rear downforce than last yearRB7ate9 wrote:How much more rear wing can they take off, as they are already running such a low AoA? Won't that create a problem for the high speed courses as the other cars that may be competitive, pace wise, will have the added benefit of less wing? While the RB9 will essentially have hit the limit already?
Or is the RB9 just that solid that they can run a near-Spa set-up for most races?
Scarbs was talking about this on twitter and confirmed the rotaries are really more a way of telling the pitlane what they want/ where they are rather than talking on the pit radio...Just_a_fan wrote:I wonder if it's there so the driver can request changes at the pitstop. It means the team don't broadcast to the world how the car is chaning over the race. Also prevents miscommunication over the radio. I would suspect that the switch is monitored in the pits and the relevant mechanics informed of the required changes just before the stop.
Likewise the central tyre switch appears to allow the driver to keep the team informed of the tyre wear situation without using the radio. I remember last year the team would ask the drivers what the tyre wear was and they would respond 1, 2 or 3. That dial has those numbers and a "pit now" position. They are obviously being careful with tyre management security this year.
