Scuderia Ferrari SF71H
Re: Scuderia Ferrari SF71H
MtthsMlw wrote:
29 Mar 2018, 00:48
Clear shot of the new diffuser even more simliar to Red Bull. Was only tested shortly in FP.
https://imgr2.auto-motor-und-sport.de/F ... 155892.jpg
Still using crossed over S Duct.
https://imgr3.auto-motor-und-sport.de/F ... 155891.jpg
AMuS
I wonder if it takes modifying the wheel winglets for the new diffuser to work properly.
George-Jung
George-Jung
Just_a_fan wrote:
29 Mar 2018, 01:28
Sevach wrote:
29 Mar 2018, 01:20
Makes sense, with Ferrari's sidepod concept you end up without room to put those small vanes.
Exactly. It was the obvious reason but some got fixated on a throw-away comment from a journo when the car was revealed.
I have too admit I am/was one of them, so thanks to all of you for guiding us noobs the right way. :D
designf1
designf1
73
Just_a_fan wrote:
29 Mar 2018, 01:12
George-Jung wrote:
28 Mar 2018, 22:51
So it is actually bending downwards on the current Ferrari SF71H....?
Yes but not enough to get into the top rad opening. As stated by some of us previously, it appears to be aimed at improving airflow over the sidepods in lieu of the devices used by other teams.
It'll probably affect the rear wing positively as well
CBeck113
CBeck113
51
wesley123 wrote:
29 Mar 2018, 10:15
Just_a_fan wrote:
29 Mar 2018, 01:12
George-Jung wrote:
28 Mar 2018, 22:51
https://i.imgur.com/R7f1DHd.jpg
It should only help the rear wing by pulling clean air from above, since the mirror air will follow the side pod profile down to the floor. That will also help direct air into the opening on the side pod, just not directly. Well done Vanja!
JonoNic
Funny thing is that the old higher RW would be in better clear air (though not necessarily more efficient). The huge air intake, the mirrors and the halo actually hides or obstructs the RW in that shot above.Image
Sent from my SM-A520F using Tapatalk
Always find the gap then use it.
CriXus
CriXus
95
Animation, showing radiators opening.
“The reasonable man adapts himself to the world: the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man.” - George Bernard Shaw
Thank you, everyone, for your kind words. I've learned a lot here and, more importantly, I've learned where and how to find and learn more. I think it's only fair to give to back to this community the best way I can. :)
F1NAC
172
I see you are informing journos on motorsport.com comment section :D Nice job, nice
Cheers :D
232
Great work Vanja. I suspected the rear wing initially but didn't have the time to do the CFD. =D>
Also the mirror doesn't have to have more drag this year. Your 2018 mirror model has very squared off leading edge compared to the 2017 model which is has a smoother leading edge. This is the reason for your increased drag.
The conclusion remains that the mirrors are for air flow to the rear of the car and not the inlets.
Piolas video has it incorrect. There is a higher pressure in front of the radiator opening even through air flows into it. Meaning it wont be "sucking" in air from the mirrors. I wish motosport.com invests in some CFD their car models are very good already.
DVB
Everybody is a Ferrari fan.
pikko18
pikko18
Vanja #66 wrote:
28 Mar 2018, 21:57
ringo wrote:
25 Mar 2018, 01:44
Fully agree with the conclusion....
Vanja, it's people like you that makes all this worth it. Much respect !
ScrewCaptain27
577
Via AMuS:
- Serj Tankian
roon
roon
412
McLaren-esque pylons. New?
