Blown Diffuser: How does it work actually and why it's there
McMrocks
McMrocks
32
Re: Blown Diffuser: How does it work actually and why it's t
bump
Exhaust blown diffuser's might return
[/url]
This link has been posted numerous times. But is it really possible?
As only the wastegate gases can be used to blow the diffuser i wondered whether those gases are enough to provide strong continuous sealing to the diffuser.
As i understand the wastegate is mostly closed. In these times drivers would feel the lack of downforce.
NL_Fer
NL_Fer
82
With two wastegates mounted directly on the left and right manifold, blowing tot the rear. There will just as much exhaust gasses during waste gate open times, as back in the v8 period.
Also during qualifying mode, the wastegate is opened, most of them time, running the turbo with the MGU-H, using power from the ES.
Maybe the can even map it to the throttle, flat out is with opened wastegate, a mm less then flat out is waste gate closed. That is if the ES is charged.
Cold Fussion
Cold Fussion
93
McMrocks wrote:bump
[/url]
The extra rear traction will be most effective on low speed turn in, and low to medium speed exist. The former may not be achievable without off throttle diffuser blowing. At traction limited events at corner exist, exhaust recovery is already compromised because the engine is not burning the full 100kg/h of fuel, so the losses from not recoverying during this time are smaller anyway. Furthermore, the most efficient exhaust harvesting one can have is to have 100% WOT time, and increasing the rear downforce on corner exist will increase the WOT percentage per lap. Each traction limited event out of corner exist will last maybe a maximum of 1-2s and each lap may only 5 such areas.
This of course assumes they are harvesting during corner exist at all, in reality they are probably spinning the turbo with the MGU-H to counter turbo lag during these events, so they wouldn't losing anything at all.
RicME85
52
Scarbs says they wont return.
The new regulations dictate the position of the second and third tail pipes, which still end in the same area as the current single exhaust.
http://www.autosport.com/news/report.php/id/121332
They could blow into ducts molded into the crash structure, and blow the top slots of the diffuser gurney.
