More likely just a presentation wing with parts missing.beelsebob wrote:Interesting lack of a DRS actuator there – built into the wing supports instead?
following design of w02 probably.Saribro wrote:More likely just a presentation wing with parts missing.beelsebob wrote:Interesting lack of a DRS actuator there – built into the wing supports instead?
Forza wrote:following design of w02 probably.Saribro wrote:More likely just a presentation wing with parts missing.beelsebob wrote:Interesting lack of a DRS actuator there – built into the wing supports instead?
Coefficient wrote:beelsebob wrote:Interesting lack of a DRS actuator there – built into the wing supports instead?
No that is not true that humps just redirect or even little disturp uper flow! This nose design is totaly downforce nevtral... It more like a knife, which slice air highest as posible to make sure that rear end (difiouzor)will heve enought airGiblet wrote:The top of that nose looks like it will produce some DF. More than a smooth nose anyway.
