Those metal stays/supports seem much larger and beefier than what we've seen on front wings in the past. Check out the ones on last year's car:
That's an interesting point, good call as there seems a close match there with those two solid metal fasteners doesn't it?!west52keep64 wrote: ↑13 Jan 2022, 13:09I think this is actually the MCL35 (last year's car) bargeboard:
https://i.imgur.com/knvpd2W.png
Are they allow an extra plane above the diffuser edge? Could be that?jjn9128 wrote: ↑12 Jan 2022, 17:28Not allowed slots in the diffuser. Could be the floor edge wing, but I thought that was only 1 element.v3rify wrote: ↑12 Jan 2022, 16:59diffuser possibly?SmallSoldier wrote: ↑12 Jan 2022, 16:52
A little front wing action?
https://uploads.tapatalk-cdn.com/202201 ... 8743e7.jpg
Good catch… Quiet cheeky of McLaren to tease us with last year’s carwest52keep64 wrote: ↑13 Jan 2022, 13:09I think this is actually the MCL35 (last year's car) bargeboard:
This mandated neutral section on the front wing was to span 250mm to either side of the middle of the nose (that is 250mm in the Y-direction of the car coordinate system). This meant that the design freedom for the aerodynamicists began at Y = 250mm. The multi-element front wings started from here.
Force of habbit I guess, but you are right, it doesn't make sense to call it the y250 vortex.wogx wrote: ↑17 Jan 2022, 16:31Can we still talk about/name it the Y250 vortex, when the neutral centre section is gone?
The intention of the front wing regs is to remove vortex generation; no sharp edges, wings must be joined to the nose, limits to variation of elements across their width.Emag wrote: ↑17 Jan 2022, 16:43Force of habbit I guess, but you are right, it doesn't make sense to call it the y250 vortex.wogx wrote: ↑17 Jan 2022, 16:31Can we still talk about/name it the Y250 vortex, when the neutral centre section is gone?
What should we call it though? The vortex generated on the front wing to manage the tire wake seems a bit long. And the acronym vgftwm isn't any better![]()
I am not very informed on what's going on. Haven't had too much time to go that deep into it. Sorry for this then, you can delete the former post I guess.Stu wrote: ↑17 Jan 2022, 16:47The intention of the front wing regs is to remove vortex generation; no sharp edges, wings must be joined to the nose, limits to variation of elements across their width.
That is (kind of) the point with the new rules, they want to stop the out-washing of turbulence. They do have the small fin above the front tyre and wheel covers. Brakes have to be ducted inside (towards the car) now as well.Emag wrote: ↑17 Jan 2022, 16:52I am not very informed on what's going on. Haven't had too much time to go that deep into it. Sorry for this then, you can delete the former post I guess.
Is there any general consensus on how the tire wake will be managed now that there are no bargeboards, and apparently no vortices?
To my inexperienced mind, it seems horrible to just let the dirty air from the tires unmanaged. Wouldn't it make a huge mess for the rear-end?
