Having seen a damper explode spectacularly on a dyno, I think it is a good idea to build in a pressure limiting device. However, it should not be quite so necessary in service use, because tyres, etc. will help to limit internal damper pressures (but don't quote me on that).RacingManiac wrote:The line of semi-active damper that we are designing now at work for off-road, heavy vehicle have built in blow-off as somekind of pressure control. Mainly to help the damper survive in high pressure event that might otherwise exceed the pressure rating of the seals. The general strategy when we are tuning the blow-off is that it should envelope the performance range of the semi-active mechanism such that normal function of the system can be retained, but it effectively clips off the force higher speed range to control the pressure.
The "blow-off" control I have discussed is intended to limit sprung mass peak velocities (& subsequent displacements) when the vehicle encounters large road inputs (e.g. kerbs), & it would (usually) be set to a much lower pressure than that required to protect the damper. If it has sufficient flow capability the same control would, of course, serve both functions.
