![Image](https://media.giphy.com/media/1swvhhiOBob51lLtHz/giphy.gif)
Wonder if it's simply case of aero unloading or if it's deliberate engineering, as I'm sure they've passed all FIA tests.
It's not the best shot to see it (may be it's just shadows), but it looks like the middle section of the FW (where the nose tip is) is looking like almost touching the ground...rkn wrote: ↑07 Apr 2018, 16:35Annual sign of spring, a flexing Ferrari front wing
http://i10.photobucket.com/albums/a147/ ... arifw2.gif
Silent Storm wrote: ↑07 Apr 2018, 17:14New inlet on both the sides, picture by Scarbs
https://pbs.twimg.com/media/DaMGuvYW0AIwh0p.jpg
https://pbs.twimg.com/media/DaMGv7kXkAAgwUb.jpg
Probably additional cooling for hot weather races...Silent Storm wrote: ↑07 Apr 2018, 17:14New inlet on both the sides, picture by Scarbs
Probably, although I wonder if it could be part of halo aero management.Mr.G wrote: ↑07 Apr 2018, 18:45Probably additional cooling for hot weather races...Silent Storm wrote: ↑07 Apr 2018, 17:14New inlet on both the sides, picture by Scarbs
f300v10 wrote: ↑07 Apr 2018, 04:19This quote from the Italian article describes the exact modification to the diffuser being discussed here, it does not say there were no changes:LM10 wrote: ↑06 Apr 2018, 23:09Thank you for the article.
So, no new floor, no changes to the diffuser and also no changes on bargeboard-area (which on some pictures seemed so). They just switched to the frontwing which was mounted on the presentation and made a slight change to the central channel.
This also means that the new floor will come to China, as said before.
"Compared to the Australian version, the Maranello team has made a small change to the central channel that, in the version seen today in the pits, seems to have a more squared shape compared to the previous version.
A solution that guarantees a better stability in the generated load, losing theoretically in expansion (to be evaluated, on the other hand, a possible slight increase in the rake angle)."
What does this mean?Vettel165 wrote: ↑09 Apr 2018, 21:37A fantastic article about SF71H (Ferrari).
https://it.motorsport.com/f1/news/ferra ... o-1023467/
With the lengthening of the SF71H wheelbase estimated to be less than 100 mm compared to 2017, the mechanical parts could be removed from the most neuralgic area of the bottom, allowing the body to create more aerodynamic load, preventing the Ferrari drivers from loading too much the incidence of wings that, instead, costs a lot in resistance to progress.
At the speed trap the Ferrari were faster than the Mercedes: Kimi Raikkonen reached 327.1 km/h against the 325.3 km /h of Lewis Hamilton, a sign that there was a clear turnaround compared to last year.
So far, Ferrari has not yet achieved the best aerodynamic balance: a new floor will debut in China that should make the SF71H even more stable (rear of the car). To overcome the problem that emerged during the winter tests, in Australia there was a tie on the bottom that was further changed for the Sakhir.
