Cam wrote:The FIA has grounds to change rules based on safety. They can also do so with all the teams agreeing - from memory.Hembrey said, in regards to that matter:
"We would like to acknowledge the willingness of the FIA, FOM, teams, and drivers to act quickly to find an immediate solution to the problem.
That would be good enough to change rules. Indeed:
However the change of specification has been unilaterally put through by the FIA on the grounds of safety. FIA president Jean Todt described it on Sunday night as “a safety problem”.
So it would seem that incident you are referring is not really the same. We should compare apples for apples.
Edit: to clarify your point - the FIA could change the rules to mandate the exact sensor rules they want - but it could only be on safety grounds or if all the teams agree. Otherwise, they have to wait until next year.
So safety doesn't change everything, consent of teams is required, and as anything (sensors) it can be questioned, when FIA changes tyre recommendations to rules it can mean as debated here:
- Fia doesn't know anything about safety either, Red Bull knows better,
- If it affects their performance they have every right to ignore technical directives about tyres, simple - their performance comes first
- There's nothing about left-right, camber, exact pressure in technical regulation so Red Bull can do whatever they want they won't break any rules, they can be DSQ and easily win an appeal
- Just because every other team complied and was negatively impacted doesn't matter, those "opinions" are meaningless their fault for listening to FIA and not doing what Red Bull did, joke's on them
OK, fine tyres/safety is not identical or the best example, "safety changes everything" but there were literally hundreds instances when clarification of rules was applied through directives which (again) were in fact accepted source of law. I still didn't get the answer why this particular case is different from legal point of view. Two ways to check it: 1. Were there any instances when technical directive (assumption it's not against technical regulations) was questioned 2. Annoying searching for examples, let's see:
- Lotus ride-height gizmo: "An FIA spokesman told Reuters that Whiting sent the directive on Friday following "a number of technical enquiries from teams" about the legality of the Lotus-type concept."
- see-saw tray "The FIA’s response was a technical directive, coded TD35. It’s not surprising that it confirmed such an splitter would not be legal. But, crucially the FIA confirmed that they reserve the right to alter the test to ensure the deflection test procedure isn’t being exploited."
- front hub: "Coming straight after another Technical Directive from the FIA, Red Bull have again had one of their designs ruled on by Charlie Whiting. It’s now the Front hub design that has stretched the rules to the point where a clarification was required. Uniquely Red Bull duct air through the front hub to vent it out through the wheel for aerodynamic benefit."
- off throttle With the FIA keen to ensure that off-throttle blowing of exhausts does not continue, the governing body has issued a Technical Directive to teams informing them that there will now be severe limitations on what is allowed next year. FIA has made it clear that the 2012 version of the software used by F1's standard ECU will now put certain limitations on engine mapping.
- RB engine maps, "Now the rules have been clarified and further restrictions applied. RBR will just have to change to their previous engine map setting or a map setting satisfying the technical directive issued by the FIA." "It has now been confirmed to ESPNF1 that the teams have been issued with a clarification surrounding the engine maps, and although the contents of the clarification have not been made public, the BBC reports that a reference map from the opening four races must be supplied to the FIA and that the directive states: "Above 6,000rpm, the maximum engine torque may vary by no more than +/- 2% (from the reference map). And the ignition angle may vary by no more than 2.5%."
And so on and so forth, bringing twenty other examples won't change anything, you get the picture. Before anyone brings that up, no it doesn't mean that every TD is not debatable but it means they were/are much more than just an opinion.
