McLaren MCL60
Re: McLaren MCL60
mwillems wrote:
13 Sep 2023, 11:35
AMG.Tzan wrote:
13 Sep 2023, 11:14
New livery unveiled but…
Aren’t these new sidepods???? :wtf:
https://x.com/wearetherace/status/17018 ... IG-LEFG3Nw
Is it not the Launch Render again?
That's what I think it is
mwillems
45
Re: McLaren MCL60
13 Sep 2023, 11:35
mwillems wrote:
13 Sep 2023, 11:35
AMG.Tzan wrote:
13 Sep 2023, 11:14
Yeah it definitely is, I just did a comparison, it is identical.
But there should be new sidepods this weekend, from what we've been told. And a floor.
This "special livery" looks to be doing some weight saving in disguise.
-Bandit
Tomsky
Tomsky
29
Re: McLaren MCL60
Macafangrskg
Macafangrskg
Re: McLaren MCL60
Really fast comparison. Gone the two steps that split and morphed the air downward and replaced by two that split the air and accelerate it more upward and more uniformly
Re: McLaren MCL60
Macafangrskg wrote:
13 Sep 2023, 13:48
https://i.imgur.com/eTMzmxA.jpeg
Excellent and clear comparison. Very speedy too - thank you very much !! Mind if I share elsewhere? Will credit
tomazy
tomazy
218
Re: McLaren MCL60
I think that the pice under the sidepod bodywork is an entirely diffirent part of the car, there just for transportation purpuses, so it is useless to compare it with the under-sidepod bodywork on assambeled car.
Macklaren
Macklaren
Re: McLaren MCL60
Macafangrskg
Macafangrskg
Re: McLaren MCL60
13 Sep 2023, 14:26
Macafangrskg wrote:
13 Sep 2023, 13:48
No problem
Re: McLaren MCL60
FOM showcar
BlueCheetah66
BlueCheetah66
Re: McLaren MCL60
Macafangrskg wrote:
13 Sep 2023, 13:48
Is it clear that the part on the top picture is the replacement for the bottom panel? Feel like we cant know for sure until it is on the actual car
Macafangrskg
Macafangrskg
Re: McLaren MCL60
tomazy wrote:
13 Sep 2023, 14:32
The floor bolt to the side pods
You can clearly see the lines of the floor connecting to the sidepod structure
Farnborough
Farnborough
111
Re: McLaren MCL60
It does look like that piece to fit on the floor topside, but in the stand appear to be stored such that we are looking at the reverse side of it (underneath) and so you have to flip it in your mind 3D to get correct view.
tomazy
tomazy
218
Re: McLaren MCL60
Aaa yes, that makes more sence now to my brain, thank you.
LionsHeart
LionsHeart
Re: McLaren MCL60
Macafangrskg wrote:
13 Sep 2023, 13:48
No, that's not true. A comparison of two photographs highlights two completely different elements. The element that covers the lower side safety structure is attached exclusively to the floor. In another photo, this part is directly a general part of the side pontoon.
Edit: I just saw that the protection casing itself was highlighted. Yes, perhaps there are some changes here, if we do not see only this element as if from the bottom reverse side.
Re: McLaren MCL60
One wing spec fitted on each car. Probably going to be close in terms of performance between the two choices again, especially with weather as it is here
