McLaren MCL38
Re: McLaren MCL38
F1.com - Upgrades
The main part of the upgrade was a new high-downforce specification of rear wing and beam wing. “This wing gives us general efficiency gains, a bit more downforce, better slow-speed performance and a better DRS gain,” McLaren’s chief designer Rob Marshall explains.
Whereas the previous high-downforce wing flap featured a completely straight trailing edge, this one incorporates the central vee indentation of the lower downforce family. That surrenders only a small amount of total downforce from the section, which is shielded by the DRS mechanism (and so less effective), to give a drag reduction even when not in DRS mode
The wing still features the separate outboard winglet sections which taper the downforce away at the outboard ends for a useful drag reduction. But the downward sweep of the lower part of these winglets is now much more pronounced and appears to integrate more closely with the geometry of the top of the endplates.
The beam wing has been reshaped to feed the airflow in a way appropriate to the reshaped main plane of the main wing.
The downforce and drag of a rear wing are determined by the shape and area of the main plane upper and lower surfaces, the flap design and geometry and how they all interact throughout the speed range.
Balancing out all the compromises inherent in making it more efficient – which has been the whole target of this development – is a hugely complex mathematical challenge taking up a lot of personnel and resource time. That explains the long lead time and the big gap between major upgrades.
The accompanying changes – more efficient front brake ducts, a re-alignment of the brackets on the floor edges, re-aligned sheaths for the front and rear suspension arms – were minor in their effect.
Re: McLaren MCL38
Oh boy, they mixed everything up with that illustration... The "Zandvoort" rear wing spec on that illustration is the one they tried out in FP1 (with Piastri I think), which is actually Singapore 23 spec and also used in Barcelona 24. Beam wing on the illustration is also older spec from Barcelona 24 (and even before that, I think) while the new spec sees a smaller lower element. Here's what both cars ran in the race
Vanja #66 wrote:
23 Aug 2024, 19:39
Not that anything else was expected, but the new wing doesn't show any signs of flow separation. It seems the flap is now steeper and obviously the frontal area is maximised, in terms of performance the DRS delta seems aligned with RB and Ferrari. Photo by motorsport
LionsHeart
LionsHeart
Re: McLaren MCL38
Vanja #66 wrote:
28 Aug 2024, 11:29
Vanja #66 wrote:
23 Aug 2024, 19:39
https://cdn-5.motorsport.com/images/mgl ... -rear.webp
On various resources where several pictures are superimposed on a photo, the authors often make mistakes. Some kind of general inattention, or indifference. When I saw the new rear wing on Friday, I was surprised when in comparisons they singled out the wing that had already been used in Barcelona. However, the fact that this is precisely the Barcelona wing, I have already carefully studied only this evening, comparing different options that have already been used earlier this season.
f1rules
f1rules
621
Re: McLaren MCL38
CjC
CjC
Re: McLaren MCL38
Don’t think we have seen a low downforce rear wing like that before with the rounded ends from anyone else?
Just a fan's point of view
Z-one
Z-one
Re: McLaren MCL38
different from spa spec
M840TR
M840TR
315
Re: McLaren MCL38
Oscar running the old spec for reference
M840TR
M840TR
315
Re: McLaren MCL38
CjC wrote:
29 Aug 2024, 10:46
Very unique design indeed. Also has a flat upper wing without the cutout / dimple in the middle, continuing the new Belgian rw design.
Re: McLaren MCL38
CjC wrote:
29 Aug 2024, 10:46
Peter Prod and his team in full swing... :D :D
Emag
Emag
108
Re: McLaren MCL38
Ah it seems like they have come up with an optimized low DF wing as well, perhaps an extension of the package prepared for Zandvort.
This looks similar to what Ferrari has brought in terms of load, although I still think Ferrari is running a bit lower.
Compared to the old low df spec, the lower element is significantly thinner.
Developer of F1InsightsHub
LionsHeart
LionsHeart
Re: McLaren MCL38
Very interesting. Good job, team! =D>
In 2024, McLaren brought a lot of modifications and configurations of the rear wing. And in general, they are all new, compared to 2022-23. And the front wing has been updated a couple of times. This is very nice to see. The aerodynamics department is working tirelessly to optimize the entire aero package, reduce drag.
Re: McLaren MCL38
CjC wrote:
29 Aug 2024, 10:46
In 2022 Alfa Romeo had triangular cut on their flap tips :)
As far as I can tell, McLaren's wing is very close to frontal area of Ferrari in the main span, but tips are slightly smaller. The main difference is camber of the whole wing, you can't see the slot on McLaren wing which tells us it's obscured by the leading edge of main element
mwillems
45
Re: McLaren MCL38
Is that the first time those Winglets on the DRS flap droop like that, or just the angle. Or is it actually cut away as Vanja suggests? The fact I would still expect to see the black outline on the winglets, but can't, suggest to me that part of the winglet has just drooped behind and lower than is visible.
That looks to be a phenomenally thin wing.
-Bandit
FittingMechanics
FittingMechanics
Re: McLaren MCL38
Wow, didn't expect such a different wing. I think McLaren expects a lot from this wing.
LionsHeart
LionsHeart
Re: McLaren MCL38
mwillems wrote:
29 Aug 2024, 11:35
No, you didn't imagine it. The upper edge of the upper flap actually falls down.
