Ferrari F10
Mr Alcatraz
-27
Re: Ferrari F10
OK here is what I’m on about! :D
Taking speed, and (possibly) weight into consideration,
did it appear that the F10 absorbed that nasty bump at turn 6 much easier than any of the rest of the cars they showed taking it?
Those who believe in telekinetics raise my hand
autogyro
autogyro
Re: Ferrari F10
Tazio wrote:OK here is what I’m on about! :D
You sure that is not because the whole car is so flexible.
They will have to bend it in the middle to get round Loews.
Sorry.
segedunum
segedunum
Re: Ferrari F10
They have a nice car Ferrari, they're the fastest and most reliable right now and they're certainly going to win a few races this year, but I wouldn't get too excited yet.
That overheating issue they seemed to have was quite a shock. As soon as they got anywhere near a car in front, and they had less then crystal clear perfect air, they had an overheating issue almost straight away. You saw it when Alonso even just got close to Vettel or Massa to Alonso. No other team had that at all, and if they find themselves down in the midfield at any time, and every team does during the year at some point, then it's going to be a real problem.
They're also still clearly thirsty.
vall
vall
Re: Ferrari F10
segedunum wrote:That overheating issue they seemed to have was quite a shock. As soon as they got anywhere near a car in front, and they had less then crystal clear perfect air, they had an overheating issue almost straight away. You saw it when Alonso even just got close to Vettel or Massa to Alonso. No other team had that at all, and if they find themselves down in the midfield at any time, and every team does during the year at some point, then it's going to be a real problem.
How do you know there was overheating when they closed to front car, if I may ask?
Re: Ferrari F10
it was said over the radio of massa if im correct
donskar
donskar
Re: Ferrari F10
segedunum wrote:They have a nice car Ferrari, they're the fastest and most reliable right now and they're certainly going to win a few races this year, but I wouldn't get too excited yet.
Please, let's get excited about something in F1! As a Ferrari fan, I am excited. Boring race, but good for Ferrari!
Not really a shock: their engine has always been one of the hottest. A solution should not be impossible.
You may be right, but if so, then the car's other components more than made up for the fuel consumption. Even if Vettel had been trouble-free, the Ferraris would have finished 2-3. Not too bad for a pair of gas-guzzlers?
segedunum
segedunum
Re: Ferrari F10
vall wrote:How do you know there was overheating when they closed to front car, if I may ask?
Rob Smedly was jumping up and down on the radio to Massa about it and Alonso was constantly ducking out of Vettel's slipstream when there was no really go reason to do so.
The thing that would worry me seriously is that changing engines for reliability issues is one thing, but changing because of fuel efficiency?! :? That's a big WTF? Even worse, because of the homologated engine they won't be able to do a thing about this fundamentally.
Speed_399
Speed_399
Re: Ferrari F10
wesley123 wrote:it was said over the radio of massa if im correct
also domenicali immediatly after the end of the race told to italian interviewer massa got temperatures problems
volarchico
volarchico
Re: Ferrari F10
This may be a dumb question, but does this mean both Ferrari's only have 7 engines left for the entire season? Or can they clean out the sand-filled first engine and use it later?
Mr Alcatraz
-27
Re: Ferrari F10
volarchico wrote:This may be a dumb question, but does this mean both Ferrari's only have 7 engines left for the entire season? Or can they clean out the sand-filled first engine and use it later?
It can be used again! It's a real mystery how much it was "compromised". If you believe Ferrari it will be ok for a cooler race climate!
segedunum
segedunum
Re: Ferrari F10
They can certainly use it again and put mileage on any of their allocation of engines, but you naturally don't want to put mileage on an engine unless you really, really have to for good reasons.
I just found it pretty strange that they changed engines for fuel efficiency reasons. We'll see what Ferrari are like at cooler venues.
mith
Re: Ferrari F10
I heard they'll use their first engine on FP as long, as they can.
Italiano
Italiano
Re: Ferrari F10
The way I understand this, is that they have 8 engines, use them how ever they please, even if they change them for every session. But the change must occur only between these 8 lumps. As soon as engine number 9 is used, because the previous 8 are dead, they get a penalty.
Correct me if I'm wrong.
#Forza Michael #Forza Jules
narkie
narkie
Re: Ferrari F10
Welcome SchumacherM! Yup each of the drivers can mix'n'match their 8 engines to their heart's content. its when they put in the 9th engine that the penalties hit
spaman
Re: Ferrari F10
Could it be, that the gills on the F10 are illegal? I know that there is a small disruption to make it part of the exhaust exit. But wouldn´t this lead to the interpretation that the exhaust pipe isn´t fully covered as is required by the rules?
Maybe some people remember the problem of the F2009 when they had to shorten the exhaust pipe last year. Wouldn´t the solution found on the F10 be illegal naming the gills "exhaust opening" since you "could see" the exhaust pipe from the top through the disruption (theoretically)?
I am a little confused.
