2023 - McLaren Formula 1 Team
Car went out of the window on the second lap I guess? Or driver errors
Ben1980
Ben1980
But 2nd and 3rd is pretty damn good!
Szabi1112
Szabi1112
Why couldnt we improve in the last lap?
Where is the Norris -effect?
Xero
32
P2 and P3 though, clearly best case scenario this weekend!
mwillems
46
Decreasing gains on the rubber and the guys didn't nail the laps.
-Bandit
mwillems
46
Sir, permission to make an observation about Oscars progress, sir!
-Bandit
trinidefender
trinidefender
318
Considering both drivers had bad sector 2 and 3's and they were close to each other physically on the track I presume that it was getting very gusty.
I think what really saved them is having the extra set of new softs for Q3 allowing them to set a banker lap.
101FlyingDutchman
101FlyingDutchman
It was S2 where they must have had a snap of sorts. Beginning of S2 was improving and then right in the middle a “yellow” bar. So a nasty snap with a gust perhaps as NOR and PIA both did a .6 rather than the .3 .4 sectors they had done on previous lap. 1.29.2 would have been possible imho
mwillems
46
Great result to be 2nd and 3rd, magnificent work by the team incl. drivers.
-Bandit
FittingMechanics
FittingMechanics
16
trinidefender wrote:
23 Sep 2023, 09:19
I just checked - Piastri would keep 2nd by 2 thousands of a second from Leclerc.
Norris would be P4 behind Leclerc.
It has to be said, amazing job by the team. Finally the team is strong enough to easily advance into Q3. It's great to watch relaxed.
Macklaren
Macklaren
Good to see Lando happy for Oscar. Great result! Let's go get Max tomorrow
trinidefender
trinidefender
318
FittingMechanics wrote:
23 Sep 2023, 09:27
23 Sep 2023, 09:19
What do you mean? Would have? I'm confused how you were able to work those times out.
Are you basing it off of Q2 times? If so then that's not accurate because it doesn't take into account track evolution and drivers realising where they can make up a bit of time.
MCLvamos
MCLvamos
Great job by the team! But as a Lando fan, I have to say that was slightly disappointing from him. Had a great Friday and start to qualifying but just didn't put it all together on those final runs like he should and usually does. Needs to snuff out these little slips as the car keeps getting better as it matters more and more.
LionsHeart
LionsHeart
Well, hello back to reality. Max remains out of reach, but I'm happy with 2nd and 3rd place, albeit 5-6 tenths more behind than I expected to see. We have good starting positions, hopefully we can collect a lot of points. Let's see what the race pace will be like.
mwillems
46
23 Sep 2023, 09:34
23 Sep 2023, 09:27
23 Sep 2023, 09:19
Piastris last lap was 1.29.540, almost the same as his first and would have stayed P2 if you ignore Lando's first fast lap.
Lando's second lap was 1.29.622
So if they did used softs and did the same second laps then they'd be 2nd and 4th.
I'm not conviced they had a gust of wind but track conditions might have affected it, but others (VER, HAM, RUS) improved so... it's seems a selective reason.
-Bandit
