So.... only one overtake manoeuvre every three laps? The leading car will drive very defensive the rest of the lap(s), to store as much power as possible to counter the attack (just like now, with the OT button).bill shoe wrote: ↑15 Nov 2017, 18:37I like the idea of making electrical energy deployment (from battery into the MGU-K) controlled by the driver, with the battery big enough to store multiple laps worth of energy rather than the single lap currently allowed. This allows a following but faster driver to store up energy over two or three laps and then blow by the leading car with the extra energy deployment. The following driver has to "earn" the saved energy by not using it while he keeps up with the leading car.
This is a much more natural way to earn and achieve a pass compared to the current artificial and gimmicky DRS. It also puts much more focus on the hybrid/electric part of the powertrain than the current Rube-Goldberg system, despite the new system being of course simpler and cheaper.
So basically: give them moped engines and ban gearboxes.JonoNic wrote: ↑15 Nov 2017, 20:52How about having a standardised crankshaft, conrods, and camshafts that are made of exotic material (FIA must ensure that these parts are durable) but they are setup to only give a spiky powerband?
The rest of the PU is up to the engineers to develop. Capacity maybe a 2l 90° v8? I'm not sure if should be turbo or NA. MGU-H/K can either be used for torque fill (to compensate for spiky powerband) or push to pass when the driver needs it.
I think a spiky powerband (if unassisted with electric power) would create more opportunities for overtakes as the cars could bog down on exits. Drivers should manage the deployment of (specified) electrical boost at any point of the lap.
Not sure about the detail but generally think the concept is great. You could do away with the computing that controls energy flows and eliminate DRS in one fell swoop.bill shoe wrote: ↑15 Nov 2017, 18:37I like the idea of making electrical energy deployment (from battery into the MGU-K) controlled by the driver, with the battery big enough to store multiple laps worth of energy rather than the single lap currently allowed. This allows a following but faster driver to store up energy over two or three laps and then blow by the leading car with the extra energy deployment. The following driver has to "earn" the saved energy by not using it while he keeps up with the leading car.
Is it about filling in the torque curve, or filling in between combustion events? It could be that it smooths the power delivery of the ICE that it is attached to. The electric motor is used to fill in the gaps between combustion strokes. Thus a hybrid power unit can deliver constant torque like an electric motor.MrPotatoHead wrote: ↑09 Nov 2017, 04:38Yes. This is what is called "Torque Fill" and is used already on road cars like the McLaren P1. The MGUK is used to fill in the gap in the torque band before the turbo(s) spool and then tapers off as the turbos come up to speed for a wider power band.markovski19 wrote: ↑05 Nov 2017, 02:28Could the MGU-K not only be used to assist with power to the crankshaft, but also to help spool the turbo and remove turbo lag. That is what the MGU-H functionally does. This could mean both the removal of the MGU-H (for costs) and the sound benefits that come with it.
With the proposal in increasing the power of the MGU-K, I don't see why this couldn't be a reality, powering both crank and turbo. Perhaps x amount of power from the K can be used to remove turbo lag through automation and stop drivers from just using KERS every corner exit, thus leaving the drivers to decide when and where to use the KERS to power the engine.
Interesting thought process.roon wrote: ↑16 Nov 2017, 01:16Is it about filling in the torque curve, or filling in between combustion events? It could be that it smooths the power delivery of the ICE that it is attached to. The electric motor is used to fill in the gaps between combustion strokes. Thus a hybrid power unit can deliver constant torque like an electric motor.MrPotatoHead wrote: ↑09 Nov 2017, 04:38Yes. This is what is called "Torque Fill" and is used already on road cars like the McLaren P1. The MGUK is used to fill in the gap in the torque band before the turbo(s) spool and then tapers off as the turbos come up to speed for a wider power band.markovski19 wrote: ↑05 Nov 2017, 02:28Could the MGU-K not only be used to assist with power to the crankshaft, but also to help spool the turbo and remove turbo lag. That is what the MGU-H functionally does. This could mean both the removal of the MGU-H (for costs) and the sound benefits that come with it.
In F1, the K is appropriately sized for this; 160hp being more than what a single cylinder can deliver (~140 hp). But is the K still selectively deployed? I don't think they're pulsing the K on and off for an entire lap.
But if they are, the smooth power output might help the longevity of the transmissions that we see. It may even influence chassis design. The 90 deg cylinder bank angle being better for installation into the chassis, but not ideal for a V6 engine. But it doesn't matter--torque fill could make the bank angle irrelevant.
Note that they have 4MJ of storage to use per lap now, and 2Mj can be extracted from the K per lap. So, in theory, the current regs could work the way you describe.bill shoe wrote: ↑15 Nov 2017, 18:37I like the idea of making electrical energy deployment (from battery into the MGU-K) controlled by the driver, with the battery big enough to store multiple laps worth of energy rather than the single lap currently allowed. This allows a following but faster driver to store up energy over two or three laps and then blow by the leading car with the extra energy deployment. The following driver has to "earn" the saved energy by not using it while he keeps up with the leading car.
