Surezibby43 wrote: ↑07 Mar 2020, 06:14A lot of variables affect balance.mmred wrote: ↑07 Mar 2020, 01:30Sure, but compared to a shorter Mercedes car with the same materials technology you still have extra weight and less balance in sharp turns.zibby43 wrote: ↑07 Mar 2020, 00:29
You can easily offset that weight by innovating with lighter materials elsewhere. There have been some credible "rumors" from someone that works at Merc GP that say the W11 is significantly lighter than the W10, and they have loads of ballast they can play with all over the car.
Technology Is a given
It Is less balanced because
I dont think those are belleville washers. That spring may likely be a machined spring.zibby43 wrote: ↑26 Feb 2020, 19:54Heave spring comparison.
Mercedes still using the Belleville washers they adopted toward the end of last season.
https://pbs.twimg.com/media/ERstJtQWoAE ... name=large
Longer cars tend to be more stable in corners.mmred wrote: ↑08 Mar 2020, 16:08It Is less balanced because
Compared to the same car with shorter wheelbase It Is less balanced on sharp turns.
Any comparison in every field Is Always done fixing other factors according to the Superposition principle. It s an engeneering first year fundamental
Tuning more factors, mainly suspension geometry, you can compensate the unbalance. But that doesnt change that you could have an even Better balance reducing the axial distance, so It Always give an advantage.... Design Is compromising
They started using them down the stretch at the end of last season.ringo wrote: ↑08 Mar 2020, 22:26I dont think those are belleville washers. That spring may likely be a machined spring.zibby43 wrote: ↑26 Feb 2020, 19:54Heave spring comparison.
https://www.designworldonline.com/uploa ... prings.jpg
The Mercedes W11 springs don't look helical to me at all, so I'd guess that they're Belleville washers.
I do not think they are washers, maybe the F1 website got it all wrong; as they do sometimes. Washers will take compression and have spring behavior, but when it comes to rebound i do not think the spring rate will be existent if the force on the element is outside of the pre-load on the washers (as the washers wont exhibit spring behavior if they lose pre-load and aren't in contact). Using washers is very limited then in terms of the displacement of that heave element to maintain the preload. From what i see, those springs are machined springs and not washers. Look on the big gaps between it.zibby43 wrote: ↑09 Mar 2020, 04:14They started using them down the stretch at the end of last season.ringo wrote: ↑08 Mar 2020, 22:26I dont think those are belleville washers. That spring may likely be a machined spring.zibby43 wrote: ↑26 Feb 2020, 19:54Heave spring comparison.
It looked to me, at a glance, like they had carried the design choice over for this year.
W10:
https://s.yimg.com/ny/api/res/1.2/gBCqK ... 413db814ad
"However, one non-aero part that did appear on the Mercedes in both Singapore and Sochi was new – and is almost certainly related to the expected ban on hydraulic suspensions for 2021. The new component was a different version of the front suspension heave spring.
The heave spring on an F1 car controls the vertical stiffness of the suspension. On the Mercedes of the last few years, the spring rate was hydraulically-controlled. Internal valves would determine the rate of flow from one chamber to another and thereby control the stiffness. But, following the example of Red Bull, the spring rate of the new component is determined by Belleville washers. These are cone-shaped springs and are often used in preference to conventional coil springs because they are much easier to package."
https://www.formula1.com/en/latest/arti ... Nkwyq.html
Also discussed here:
https://finance.yahoo.com/news/gary-and ... 39677.html
Merc's old setup was hydraulically actuated. It looked like this:
https://www.formula1.com/content/dam/fo ... /image.jpg
It wouldn’t make much sense to revert, considering the rule changes coming up in ‘21.
Looks pretty similar to the end of ‘19 setup to me.
I think previous red bull cars may have some clearer pictures. And the spring does not have to be helical because it is machined into any shape that is desired. It is not wound like a wire spring.
ringo wrote: ↑09 Mar 2020, 17:41If these are washers, and as they appear not to be touching the next adjacent set of thicker washers, then the heave element is quite complicated.
It is a series of spools or cups that the washers sit on, and each spool can float axially and seat at the back of the next adjacent spool, followed by a pilot shaft that also floats and centers the heave element.
The ends of the spring unit look to thin down in a helical fashion to me. It could be a 2 or 3 start spring that would reduce the angle.
Probably a bit of droop going in all the images we see with the cars up on stands. Would they necessarily run pre load when off the ground?
