2021 Alpine F1 Team
Tooooom
Tooooom
Re: 2021 Alpine F1 Team
Summer will be long if that’s the case.
RedNEO wrote:
08 May 2021, 13:20
Track temp might play a key role.. they were a bit faster than FP1 but slower than FP2.. either way Q3 seems a little out of reach with both cars setting nearly identical times. Just have to hope they find something before Q
Based on FP3? Your presuming they were trying to put in a faster lap than yesterday. I try not to be too high or too low.
We'll find out soon enough.
max_speed
max_speed
what a lap from ocon .that lap for sure gonna put alonso into dipression :)
politburo
politburo
max_speed wrote:
08 May 2021, 16:15
Not really...I was watching Alonso onboard, and he Alonso nearly spun at T15 trying to go on his final hotlap - probably due to cold tyres from all the farcical queuing at T13. This just snowballed into a bad lap - but P10 is good and the points are won on Sunday.
"Nosotros diferimos, pero nosotros todos son iguales"
max_speed
max_speed
politburo wrote:
08 May 2021, 16:18
max_speed wrote:
08 May 2021, 16:15
i still dnt understand logic to be so late going for final run. alpine is not fighting for pole why cant they go 30 seconds earlier and be head of queue. alonso still not 100% so why not reduce risk upfront.
politburo
politburo
politburo
politburo
politburo wrote:
08 May 2021, 16:18
max_speed wrote:
08 May 2021, 16:15
Still needs to improve. Part of the problem was his first Q1 wasn't fast enough, he had to use a 2nd set of tires. This ended up in him being able to have 1 set of softs for Q3,
politburo
politburo
diffuser wrote:
08 May 2021, 16:24
politburo wrote:
08 May 2021, 16:18
max_speed wrote:
08 May 2021, 16:15
Leclerc and Norris also went for the first Q3 hotlap on used soft. Alpine their problem is they always go last, they did this in Portimao Q2 as well, Alonso waited 2 or 3 minutes extra in the pits for him to be released only to not a good lap.
fouad1979
fouad1979
Now he has to do more its his 4 GP since his come back its his fault what happen before his fast lap it was a rookie mistake
politburo wrote:
08 May 2021, 16:27
diffuser wrote:
08 May 2021, 16:24
politburo wrote:
08 May 2021, 16:18
Did Alo get effected the Perez spin ?
fouad1979
fouad1979
diffuser wrote:
08 May 2021, 16:28
politburo wrote:
08 May 2021, 16:27
diffuser wrote:
08 May 2021, 16:24
No he was a front
fouad1979 wrote:
08 May 2021, 16:30
diffuser wrote:
08 May 2021, 16:28
politburo wrote:
08 May 2021, 16:27
No he was a front
Not that it mattered, he was on used tires.
fouad1979
fouad1979
diffuser wrote:
08 May 2021, 16:36
fouad1979 wrote:
08 May 2021, 16:30
diffuser wrote:
08 May 2021, 16:28
No he was a front
Yes i know he need to improve his qualy cause his losing ground to Ocon 6 thents here in barcelona its huge
politburo
politburo
fouad1979 wrote:
08 May 2021, 16:40
diffuser wrote:
08 May 2021, 16:36
fouad1979 wrote:
08 May 2021, 16:30
No he was a front
If you account for the mistake it is probably 3 or 4 tenths. T15 is where you build speed for your hotlap and clearly he wasn't able to do that but it is certainly his fault. But Alonso has very good race pace, as we saw last week in Portimao.
